NooTheme Premium WordPress Theme › Forums › CitiLights › Our Featured Exclusive Slider \ Primary Fields \ Static Width
- This topic has 8 replies, 3 voices, and was last updated 7 years, 4 months ago by
simontea.
7 years, 5 months ago #1073488
Citilights is using 3 Primary Fields for sliders with static width. It is possible to configure display one or two fields instead of three, which is great. My question is, if it is possible to have this configured with dynamic field length, so when two columns or one is displayed, the field can show more characters in the row?
It is very useful, when a customer has a little more information to display, but still wants to have it in one row, than he can configure two fields instead of three and have this information fit.
This is not a critical issue, but if someone can consider to include this adjustment into the next release, it would be much appreciated.
7 years, 5 months ago #1073491This reply has been marked as private.7 years, 5 months ago #1073499The same static width is in Similar Properties & Properties List
7 years, 5 months ago #1073554
We are so sorry for the late response because we took part in a long national holiday in our country so we cannot help you during that time.
For your question: Currently, we haven't supported a dynamic column for Recent Properties shortcode because we also supported Layout Style and Property Style. It will be a mess if we integrated options too much. If you really want to make it, we will try to discuss with our developer and they can help you with an extra fee.
7 years, 5 months ago #1073579This reply has been marked as private.7 years, 5 months ago #1073644
Thanks for your feedback.We understood a part of your question. However, we also got access to your website: http://drupal.officeleasingrichmondbc.com/
we didn't see the section as your image.
As we understood, you want to remove "r" at the end of your price but we didn't see it on your site.
7 years, 5 months ago #1073678This reply has been marked as private.7 years, 4 months ago #1073812Hi again.
We have added the custom CSS to help you fix that issue.
7 years, 4 months ago #1073841Hi Jackie,
Thank you very much for adding the code to custom CSS, I've tested it and it works exactly the way I needed.
I also figure out that I need to add the same code to .page-fullwidth .properties.list .property-fullwidth-info.property-info
Now all the forms show the additional price in one line.
I really appreciate your help with this issue,
All the best,
Simon
