NooTheme Premium WordPress Theme › Forums › Palazzo › Order by square meters not working properly and compatibility on safari browser
- This topic has 13 replies, 2 voices, and was last updated 4 years, 12 months ago by
5 years ago #1212190
Hi, i have two things i need to fix.
1. Inside this page: https://5thavenueimmobiliare.it/immobili/?orderby=area-desc when i try to click on mq (square meters) the filter is somehow inverted. mq decrescente (decreasing) shows the houses in increasing order per sqare meter and not the other way.
2. On some safari searches when going to the same page (https://5thavenueimmobiliare.it/immobili/?orderby=area-desc), when clicking on a house the page scrolls to the top and i need to scroll down and click again.
Can you help me out?
5 years ago #1212206This reply has been marked as private.5 years ago #1212210This reply has been marked as private.5 years ago #1212212This reply has been marked as private.5 years ago #1212213This reply has been marked as private.5 years ago #1212230Dear, I check your site on Safari but i don't see any problem like your problem, Please kinbdly see Video and check your site again.
Also, Please kindly update 'Realty Portal plugin' on your site to latest version 1.2.8 to fix problem when order with area.
5 years ago #1212268This reply has been marked as private.5 years ago #1212279Dear, I have login to your site then go to admin menu 'Palazzo -> Dashboard -> Install Plugin' and update Realty Portal plugin on your site to latest version 1.2.8 .Now please check property order problem on your site again.
5 years ago #1212297Hi, thanks for updating the plugin. I see that order by price and mq (square meters) are working. But the third option, by ID, is not working at all. could you take a look?
As fot the problem 2 how can i solve it? it's a problem of the theme
5 years ago #1212306Dear, I check your site and i see the key you use to oder is 'ref' Sorry, the theme not support order property by ref (see attachment)
Also, Sorry, i can't help you to fix problem because i not see it on my safari. Please kindly check again.
5 years ago #1212310Hi, thanks. What other kind of order by can i use?
5 years ago #1212326Dear, You can use order by 'date' and 'date-desc'
4 years, 12 months ago #1212387And how can i change that?
4 years, 12 months ago #1212399Dear, I have login to your site and change property order ID to Date in file 'yourtheme/realty-portal/page-layout/page-archive-property.php' Now, Please check your site again.
