NooTheme Premium WordPress Theme › Forums › JobMonster › order by "random"
- This topic has 5 replies, 2 voices, and was last updated 7 years, 7 months ago by
7 years, 7 months ago #1068369
how can I sort the resume result page by "random". ==>order by "random".
7 years, 7 months ago #1068493
Thanks for your contacting us.
We received your question in the past and we also discussed with our developer. However, we haven't found the solution for it yet.
We will contact you if we find the best solution.
7 years, 7 months ago #1068832any news?? this feature should not be that difficult to implement
7 years, 7 months ago #1068921
Posts: 3295Hi again, alex91
We added this question in our list then our developer will take a look it. After that, they will consider adding in Jobmonster theme in the future.
7 years, 7 months ago #1069451to every question I ask, you write the same answer "We added this question in our list then our developer will take a look it. After that, they will consider adding in Jobmonster theme in the future."
You wrote me privately in a pre sale inquiry that if there is a fetaure missing, you will support the user to find the best solution or to help him how to add this feature. So far, you didn't really support me. Why?
7 years, 7 months ago #1069480
Firstly, we are really so sorry if you aren't satisfied with our theme and our support services but we want to explain below:
1- Before buying Jobmonster theme, we think that you see our demo website and description carefully. Then you understand a part of Jobmonster's features.
2- We always tried to answer loads of your questions but some questions related to customizing our theme. In case, we often recommend customers 2 ways:
+> They should find a freelancer to help because Jobmonster is a common job's website, we cannot cover all features which one of customer requested. The jobmonster theme is based on salient features of a job's site.
+> If any customization questions which we can help for example change color or link, etc. We also help with the free fee but some complex questions, we will help with an extra fee if possible.
In addition, for your questions, you also ask many questions in this forum and we also tried to answer you in our ability. Thus, if you have questions related to customizing our theme, we also consider it carefully. If it is appropriate for a job's website, we will try to make it as soon as possible. If you want to do it immediately, you should find another way. Maybe find a freelancer.
We hope, you can understand it.
Thanks so much.
