- This topic has 2 replies, 2 voices, and was last updated 6 years, 2 months ago by .
Viewing 3 posts - 1 through 3 (of 3 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › Order By does not work on the property listing.
None of the select "Order by" options work. It does not produce any change in the list of properties resulting from a search. This doesn't work as much on the site I'm developing as it does on the Palazzo sample site.
I also take this opportunity to ask if possible to add the option "Order By Ref" in the same select, since it is a common request of my clients.
The URL of the site is:
Dear, please kindly update Noo Palazzo theme on your site to latest version 1.2.3 from ThemeForest then check your problem again.
Combo changes now take effect. Although I expected that if the Featured option was chosen, the featured properties would be displayed first and then the rest. Now only the featured ones are shown and the rest are not, it works like a filter. On the other hand, I don't see the option to Order by Ref, will you be able to incorporate it? From already thank you very much.
