NooTheme Premium WordPress Theme › Forums › Timetable › noo upcoming class
- This topic has 6 replies, 2 voices, and was last updated 7 years, 1 month ago by
7 years, 2 months ago #1076212
Hi TB,
I use on my site the shortcode noo upcoming class.
As I understood this shortcode it shows all classes which are starting in the future and classes which are still going on, right?
So it should NOT SHOW classe which are over, aren't they?
But this is the case: in my class overview where I use the above shortcode there is still a class which is already finished but still shows on that page.
See here: https://isi-ev.de/kurse-selbstaendige/
It is the first class on the left first row "Steuern und Buchhaltung" This course ended on June 19th, and it's still visible.
This class should not be visible anymore. Can you help?
You have the login to the site.
Thank you very much.
Regards
Oliver
7 years, 2 months ago #1076222
Posts: 3295Hi again, Oliver
Because you have configured Set Dates Manually for your class. For instance, this class: Steuern und Buchhaltung- it will be configured the date from May to June. That's the reason why this class displays on the Upcoming Class shortcode.
You can see these images: https://prnt.sc/o6q7sq
7 years, 2 months ago #1076263Hi,
I think you did not understand me (or do not know, how your shortcode is coded):
I set the dates manually until June, 19th of the above mentioned class. As I explained above the shortcode I use should NOT display the class anymore because it is neither upcoming nor running. It is over and in the past rerfering to the date of today.
So, why it is still there?
When I put a test-course by weekly schedule and the schedule, i.e. ends a week ago, this test-course will not be displayed. You should experiment it.
I need a solution for that, really.
Regards
Oliver
7 years, 2 months ago #1076278
Oh, I am so sorry, I had a wrong calendar on my computer.
Can you give us your FTP account exactly? After that, our developer will check this issue.
NooTheem
7 years, 2 months ago #1076365This reply has been marked as private.7 years, 2 months ago #1076847Hi, did you resolve this issue?
Cheers Oliver
7 years, 1 month ago #1076937
Thanks for your feedback and we are so sorry for the late response. We were so busy, that was the reason why we cannot help you.
It seems that you fixed this issue, didn't you? Because we also got access to your site then realized that it fixed. Please let us know if you still need to help.
We are really sorry and thanks for your understanding.
