NooTheme Premium WordPress Theme › Forums › Organici › noo product grid widget
- This topic has 14 replies, 2 voices, and was last updated 5 years, 11 months ago by
6 years ago #1098583
Is possible to have the Noo product grid widget in the products page?
6 years ago #1099967Dear, it's postion will display Shop page content or Product Category Description, Please update Organici theme your site to latest version 2.0.7 from ThemeForest, then you add Shop page content or Product Category description, will display in that position.
6 years ago #1100243But I cant put some widget only text
6 years ago #1100246Sorry, it's only support Text or Shortcode.
6 years ago #1100255ah ok, and an other question, whem I use the Noo product grid widget I dont see all products in the categories, only a few and in same categories no one
6 years ago #1101163Sorry, i don't understand your problem. please kindly give for me more details and admin account your site via private reply, i will check details to help you.
6 years ago #1102196This reply has been marked as private.6 years ago #1102199This reply has been marked as private.6 years ago #1102204j5 years, 12 months ago #1110347Dear, please kindly send for me your problem URL, i will check to help you.
5 years, 12 months ago #1110353You can see than I have hide Noo product grid widget in the home page with the name ---> "Tu Tienda Online de Productos Naturales para Perros y Gatos"
Best regards
5 years, 12 months ago #1110596Dear.
I see that not is problem, please go to edit 'Noo Product Grid shortcode' you will see setting 'Limit' is '8' , mean, the shortcode only select 8 product on all product category of setting 'Choose Categories'
best regards.
5 years, 11 months ago #1112570Ok, and an other question, Is it possible to make a carrusel instead of a product list? I would like to see only 4 or 5 products and also an option to "see more" button.
Best reards
5 years, 11 months ago #1112683and it is possible to see these icons in the mobile version?
5 years, 11 months ago #1113006Dear,
1. If you want use it as slider, please remove it and use 'Product Product Slider' shortcode in WPBakery Page Builder2. if you want show it in mobile, please add custom css on your site
@media (max-width: 480px) { .noo-product-filter.masonry-filters li a{ text-align: center; } .noo-product-filter.masonry-filters li a img{ display: inline-block; } } -
