NooTheme Premium WordPress Theme › Forums › Hermosa › Noo Event Carousel not showing properly on home page
- This topic has 13 replies, 2 voices, and was last updated 4 years, 9 months ago by
Olivier.
4 years, 10 months ago #1217484
The noo theme Event widget is not showing correctly on the homepage:
Also, the right and left arrow are not behaving smoothly.
4 years, 10 months ago #1217486Dear, Please kindly send for me admin account your site via private reply, I will check details to help you.
4 years, 10 months ago #1217487This reply has been marked as private.4 years, 10 months ago #1217488This reply has been marked as private.4 years, 10 months ago #1217489This reply has been marked as private.4 years, 10 months ago #1217491This reply has been marked as private.4 years, 10 months ago #1217495Hello,
Ok. I understand. But, since I need Elementor, we can't just deactivate it and that's it. I have other landing pages builder with Elementor so please don't deactivate Elementor and leave the site like this, otherwise my other pages will brake.
My question is, can I rebuild my home page using Elementor and still using the Noo Theme Widget like Event slider Widget and Noo Class Widget.
If they conflict with Elementor, can't you update them in order that they don't conflict anymore?
Thank you,
4 years, 10 months ago #1217501Dear, Because the event slider on Hermosa theme only work with WPBakery plugin. To fix your problem, you need disable Elementor script on page use event slider. If you want do it. Please install and switch your site to use Hermosa child theme. Then add custom PHP code in file
functions.phpof Hermosa child theme.add_action('elementor/frontend/after_register_scripts',function(){ global $post; if($post && $post->ID == 'PAGE_ID'){ wp_deregister_script('elementor-frontend'); wp_deregister_script('swiper'); } });Please change
PAGE_IDto page id you want show event slider.Best regards.
4 years, 10 months ago #1217502Ok. I see. We can try this.
And what about the Menu Icon on mobile devices that conflict with Elementor Kit? Can I use a similar way to fix that issue?
4 years, 10 months ago #1217503This reply has been marked as private.4 years, 9 months ago #1217522My Question is, are you going to resolve the conflict with Elementor in order to make the theme fully compatible with Elementor?
4 years, 9 months ago #1217546Would it be possible for you to update the theme with some correction in order to solve the conflict with Elementor and make the Theme fully compatible with Elementor?
4 years, 9 months ago #1217548Dear, only custom event carousel shortcode for WPBakery is conflict with Elementor and you can use custom Code to resolve it. Also, you still can use theme with Elementor.
4 years, 9 months ago #1217552Right. But I don't know how to do this and there is chances that I mess up the website through the process.
Why don't you just update the theme and make it fully compatible with Elementor, so you solve the problem for everyone once for all?
