NooTheme Premium WordPress Theme › Forums › JobMonster › New Job Postings structured data issues detected
- This topic has 13 replies, 2 voices, and was last updated 3 years, 6 months ago by
3 years, 6 months ago #1218908
AnonymousInactiveTopics: 28
Posts: 73I have enabled the Jobposting schema on our website but getting error from google search console as below:
"New Job Postings structured data issues detected"
Please help so i can fix this.
3 years, 6 months ago #1218926Hello.
Please give us your site URL, and admin account. We will help you check it soon.
3 years, 6 months ago #1218931
Posts: 73This reply has been marked as private.3 years, 6 months ago #1218937Hi again.
Please check the theme file permission, we can't edit your source code via the WP File manager plugin.
3 years, 6 months ago #1218946
Posts: 73Please check now, the permission granted.
3 years, 6 months ago #1218952You forgot to set the permission for the folder and file on that folder.
3 years, 6 months ago #1218957
Posts: 73Please try now.
3 years, 6 months ago #1218981Hi again.
We have checked and fixed the hiringOrganization field missing. For the jobLocation field missing, I see you don't input the address to the job.
We use the job address to render the jobLocation field for the job posting.
Please recheck it again.
3 years, 6 months ago #1218982
Posts: 73Why you use the address when you can use the location itself?
Why not the /job-location/ ?
its not necessary the employer puts the address, but yes its necessary for the location through (/job-location/).
Please advise.
3 years, 6 months ago #1219001As you see, the job posting needs some attributes as jobLocation, address, streetAddress, postcode...
We use the full address field to check the address and render the value for the job posting attribute. Your job will miss some attributes for the job posting if you don't use the full address field.
You can check it on our source code at this file: wp-content/themes/noo-jobmonster/framework/job/job-template.php line 302.
3 years, 6 months ago #1219003
Posts: 73Dear Jackie,
Google wants the jobLocation to be fixed.
see the message from the search console, we can't even validate it as no value found.
please advise.
3 years, 6 months ago #1219020
Posts: 73Any update on this please?
3 years, 6 months ago #1219022
Posts: 73Dear Jackie, please make the location schema as per "/job-location/"
we use cities as per ISO codes, and google will recognize them easily.
3 years, 6 months ago #1219042Hi again.
We have changed the source code at this file: wp-content/themes/noo-jobmonster/framework/job/job-template.php line 292 to help you add the jobLocation schema.
itemprop="jobLocation" itemscope itemtype="http://schema.org/Place"
