NooTheme Premium WordPress Theme › Forums › JobMonster › Need help with a few issues.
- This topic has 17 replies, 4 voices, and was last updated 7 years, 7 months ago by
7 years, 7 months ago #1068330
Hi..
This topic is about website: http://www.zzpned.nl
1 & 2; how can i translate this line of text; https://gyazo.com/9a33625e6a36855e22d0a36d0ffaa0ab
3; when i try to remove the capital on the word "Categorieën" and add the capital on "subcategorieën" and save it it won't update it. Can you check for me, you can see when you login aswell; https://gyazo.com/1303aba5751e68e6313ba28cf9c54082
4. Thanks I've got that now, i just can't get it to sit right in the child theme, i've made the correct folder structure in the child theme but the translated lines wont show up. Only if i replace it in the main theme it will work. Maybe some advice on the placement?
5. Heres the picture, you can find these at the company to give them a rating, also it shows '' string(1) 7" at the upper part of the picture, can you see whats wrong there?
https://gyazo.com/52a7a4cfbb0e55c1eecf81bf87eb635a7 years, 7 months ago #1068397
1- First, you can copy source code from {root}\wp-content\themes\noo-jobmonster\assets\js\noo.js to {root}\wp-content\themes\noo-jobmonster\assets\js\min\noo.min.js then find Search text in line 677.
2- You can go to JM Jobmonster > Custom Fields> find job_category then change Field Plural Label. Also, see this image:https://prnt.sc/mjv09b
3- We are so sorry but you need to check it by yourself because it is too difficult for us to help you. Because we don't know your change exactly and it also out of our support service. Hopefully, you can understand it.
5- Please give us your information including your admin account and FTP account exactly and privately. We will help you to check it.
7 years, 7 months ago #1068435This reply has been marked as private.7 years, 7 months ago #1068700Hello,
why am I not recieving any replies?
7 years, 7 months ago #1068724Hi again.
Sorry for the late response
1.2, With the search placeholder on the field select, please check the code at file
https://zzpned.nl/wp-content/themes/noo-jobmonster/assets/js/min/noo.min.js
you will see the string to change.
3. We have checked your site and fixed the issue with job category and job tag field label. Now it can change the field as you want.
4. With the child theme to load the js file, you need to add the code
add_action( 'wp_enqueue_scripts', 'noo_datatable_scripts' );
function noo_datatable_scripts() {
wp_register_script( 'noo-DataTables', get_stylesheet_directory_uri() . '/datatables.min.js', null, null, true );
to child theme. We have added this code to help you overwrite the datatables.min.js in the child theme.
7 years, 7 months ago #1068741This reply has been marked as private.7 years, 7 months ago #1068805
Posts: 3295This reply has been marked as private.7 years, 7 months ago #1068811What would it cost to get these 2 things done?
7 years, 7 months ago #1068812Hi topic owner,
I access your website and i saw you have beautiful thing that might be custom your self, that search bar background transference as screenshoot
could you please give me this custom code for this .Thank
7 years, 7 months ago #1068872
Posts: 3295This reply has been marked as private.7 years, 7 months ago #1068894This reply has been marked as private.7 years, 7 months ago #1068897
Posts: 3295This reply has been marked as private.7 years, 7 months ago #1069022My client will let me know if he wants this.
I have a few more questions:
1. How can i translate this string when posting a job, won't show up in loco translate:
https://gyazo.com/5e7079ec1f42bb11242368283d17f2df2. I have social media icons in my footer, sadly I can set them to open in a new window. How can I accomplish this?
3. This printscreen shows information from the persons profile information or showing their CV. It will only show the text and not the subject like; e-mailadres: [email protected]. It's just the e-mail showing. Can this be changed and how? https://gyazo.com/797f430ae1ab2f98476b5831f373f72a
4. When updating the theme we now got a option to block companies, I do not want to use this in this website. Where can i disable this? Or how can I disable this?
5. When trying to leave a review to a company it won't place it. Can you guys see what's going wrong?
7 years, 7 months ago #1069049
1- We also got access to your website then created a new language from Loco Translate section. In this case, we still found these texts, please see this image: https://prnt.sc/mogfl5
2- We are so sorry but we don't understand your question clearly. Don't you want to open these social media in the new window?
3- In this case, you can go to JM Jobmonster > Custom Fields > Candidate > Then add Field Icon for each field. Please see this image: https://prnt.sc/mogkx6
4- Can you give us an image to describe your question?
5- Please give us your FTP account privately and exactly. We will help you to check it.
7 years, 7 months ago #1069087This reply has been marked as private.7 years, 7 months ago #1069174
1- We think that you should create your language file again because these languages were created a long time ago so some of them aren't updated continuously.
2- We are so confused about this question because currently when we clicked to your social icon, it will be redirected to a new window.
3- We need much time to discuss with our developer about this question. After that, we will feedback you soon.
4- Please go to JM Jomonster > Settings > Member Menu > Candidate Heading Menu then removes Block Companies from your list.
7 years, 7 months ago #1069201Thank you again.
1. Okay thanks
2. The social icons in the footer do not open in a new window for me. They open in the same windows. The ones at the topbar do open in a new window. So it's the footer ones that do not open in a new window whilst I want them to be: https://gyazo.com/fc900d9421232d7c31c417bd68f25d3e
3. Okay thank you.
4. Thank you this has been set.
5. I sent my FTP details but no answer on the issue "5. When trying to leave a review to a company it won't place it. Can you guys see what's going wrong?" Can you check?
7 years, 7 months ago #1069328
2- We also got access to our website then checked it. This is our default. In case, we will discuss with our developer then they will check it soon.
4- Our developer also had access to your website then find out this issue related your custom code in the Child Theme. Please see children theme/layout/company/list-comment.php
You should delete list-comment.php file on your source code.
