NooTheme Premium WordPress Theme › Forums › JobMonster › Need Help For Some Words Location
- This topic has 16 replies, 2 voices, and was last updated 7 years ago by
amity786.
7 years, 1 month ago #1080493
I try To Find the location of some words and I could not found that. That I'll attached here the screen shots.
Some messages also not translated correctly:-
1- 'Congratulation! Your resume passed our application round.','noo'
2- "Hi,\nWe received your application for the job and found your skills and experience does not match our requirement. Thank you for your interest in our vacancy and good luck in your future career.\nBest regards.",'noo'
3-"Congratulation! \nWe received your application for the job and found your skills and experience matched our requirement. We will contact you for detail of the second selection round soon.\nBest regards.",'noo'
4-'Unfortunately! Your resume didn\'t pass our application round.','noo'
Waiting For Reply
Thank You
7 years, 1 month ago #1080495This reply has been marked as private.7 years, 1 month ago #1080517Hi,
You go to WPML -> String translate -> http://prntscr.com/pm4m6h
- Slug translate: I helped you translate "member" slug.
With the endpoints query var (manage-job, manage-plan ...) : There are a few difficulties, currently we have not integrated them into WPML.
- With other text: We will have 1 release at the beginning of next month.
7 years, 1 month ago #1080620Hi Again,
Your website was updated and i suffered problems with login and reset password....
Anyhow login problem was resolved.
Q 1 - What i mentioned 1, 2, 3, 4 lines, I want the location of that lines, because i translated already that lines. But that messages not sending properly in 'hebrew' section. It works perfect in 'english' section.
Q 2 - In 'hebrew' section forgot password is redirecting in 'english' section forgot password page. Need help for this
Q 3 - In Quote - #1080495, i attached 2 screenshots. In that screenshots i marked several words( slug translation is not a problem here), need to translate the words and i can't translate that. Need help for this.
Q 4 - In 'hebrew' section, in Post a job page, Job Category (only that) is not translated.... Need help for this
Thank You
Waiting for reply
7 years, 1 month ago #1080635Hi,
1. You go to WPML -> String Translate -> http://prntscr.com/pne0gq
You can apply a job and check email.
2. Solved!. http://prntscr.com/pneeyf
I am not sure why this code is here.
The original code must be <?php echo wp_lostpassword_url ();?>
3,4 Please update the Jobmonster last new version. (You should backup your theme before update).
7 years, 1 month ago #1080677Hi again,
Thank You For reply
and thank you for updating several words.
1 )- Several words still need translation
example -Recommend size: 1400x600px
( i'll attach a screen shot)
2 ) - about 'forgot password' it's working perfect in desktop, but it's not working in mobile browsers.
when clicking the'forgot password' link it's redirect to same page (login page)
3 ) - is it possible to keep 'post a job' button only in employer section ( i mean only hebrew section, because hebrew section only for employers)
and
is it possible to keep ' post a resume' button only in caregiver section ( i mean only english section, because english section is only for caregivers)
Thank You
waiting for reply
7 years, 1 month ago #1080752Hi,
1, Currently jobmonster also has this problem. I will check it and update it.
2, I add the login poup instead of redirect to link.
3, Jobmonster does not currently support this feature.
7 years, 1 month ago #1080758Hi Again,
Reply for - #1080752
1- Please do the update soon for these words.
2- Please try in mobile browser, click the link of 'forgot password' it's not working. (still i have same this problem)
( in desktop 'forgot password) works fine)
3- In future updates please add this future. It's more useful. Thank you
Thank You
7 years, 1 month ago #10807852. You can try again with the function forget password.
7 years, 1 month ago #1080817Hi Tinhbeng,
Thank you very much for the great help.
Now it's works perfectly, what type files you changed!!!!
Because after 'updating' the theme in upcoming days, the problem will be repeat....
I uploaded a screenshot, its a 'edit' button in 'manage jobs'
Is this function is not working?
7 years, 1 month ago #1080905Hi,
I created a job but didn't see it show in "Manage Job". What customizations do you have for this page?
7 years, 1 month ago #1080950Hi Tinhbeng,
Thank you for reply,
I was so shocked, when i saw it in my manage job page!!!!!!
I can't see the 'jobs' in 'manage jobs' page!!!!
I really don't known, how it's happened......
I tried lot to slow this problem, but didn't found the solution for this.
So please i need help for this.
Waiting for reply
7 years, 1 month ago #1080959Hi,
You need to assign company to a user.
- Edit Job not work:
I'm not sure this issue.
I have printed the "edit job" url and it returns the desired value. But I don't know why the "edit-job" endpoint was deleted when rendering the html.
I have tried deactivate plugin
WPML Multilingual CMS => url is back to normal. You can contact WPML support for better support on this issue.
7 years ago #1081025Hi Again,
Thank You for reply,
1 - This website is in 2 languages, so noo counter shows the numbers double (example- if there is 5 jobs in hebrew and it's translated in english 5 jobs. so it's shows 10 jobs in noo counter),
2 - I checked the edit button, there is wrong with wpml.
But i decided to remove it. So please tell me, from which file i'll remove the codes and which codes i remove? to remove the edit button.
3 - In home page of hebrew, i want to make the '100+' in right side, is there is any idea for this?
Thank You
waiting for reply
7 years ago #1081077Hi,
1. We use the function "wp_count_posts" to count post.
Currently WPML does not have any hook for this function.
You can send me FTP account. I will make some customizations, hope to help.
2,3. You can add these lines to Custom CSS:
.member-manage-action .fa-pencil {
display: none;
.rtl .search-main-title {
text-align: right;
7 years ago #1081109Hi Again,
Wow!!!
It was amazing.... it works perfect!!!
Thank you so much
2 and 3 number problems are resolved.
only 1st number need help
In upcoming updates please add these below words in wpml
Showing %1$d–%2$d of %3$d resumes
Recommend size: 245x245px
Recommend size: 160x160px
Recommend size: 145x180px
Thank You
7 years ago #1081110This reply has been marked as private. -
