NooTheme Premium WordPress Theme › Forums › JobMonster › Multiple companies and jobs
- This topic has 9 replies, 2 voices, and was last updated 2 years, 4 months ago by
MKuegler.
2 years, 6 months ago #1220974
I urgently need your help, and I'd like to start with the most important point.1. How can I create a solution that allows a registered person (employer) to create multiple companies and jobs? This is very important for us. There should also be a solution via the forms in the frontend.
2. Can I also filter the companies and only display the companies in a certain location? This is possible for the jobs, but I also need this for the companies.
3. Is it possible for the admin to assign packages manually if the process is carried out in person and not via WooCommerce?
Many thanks in advance for your help!
2 years, 6 months ago #1220997Hello,
We urgently need your help with these points.
Could you please support me?1. how can I create a solution that allows a registered person (employer) to create multiple businesses and jobs? This is very important to us. There should also be a solution via the forms in the front end.
2. can I also filter the companies and only display the companies in a specific location? This is possible for the workstations, but I also need this for the companies.
3. is it possible for the administrator to assign packages manually if the process is done in person and not through WooCommerce?
Thank you in advance for your help!
Yours sincerely2 years, 6 months ago #1221013Hi.
1. The company can create a job, but I don't know what about the business. Please let us know more about that.
2. We have supported the search company widget to filter the company by location, category, or company size. https://prnt.sc/FDK9A7DImyhE
3. Yes, you can create an order via the backend and assign it to the company as you want.
2 years, 6 months ago #1221017Hello, thank you for your help!
1. i would like to give an example to explain it, as it concerns a large part of our customers.
An employer registers and creates a company profile (free of charge) in order to post job advertisements via a package.
However, most of our customers have several companies.
So can we make it possible for an employer to register and create more than 1 company? We would like to give our customers the option of creating 2 companies, for example, and then posting jobs under them.2. thank you very much, I will test it.
3. great!
2 years, 6 months ago #1221034This reply has been marked as private.2 years, 4 months ago #1221221Hello Jackie,
is there a possibility that the author of the theme can include this?Thank you!
2 years, 4 months ago #1221236Hi.
We will check and update the Noo Company widget to help you get the company by location or category.
Please wait for us.
2 years, 4 months ago #1221247Hello Jackie,
many thanks for that. I was referring to the issue of 1 user (1 login) with 2 companies and multiple jobs.
https://nootheme.com/wp-content/uploads/2024/03/Support.jpg
Thank you for your effort!
2 years, 4 months ago #1221256Hi.
Sorry, we can't help you do the feature for one user with 2 companies and multiple jobs. It needs to change your theme logic and a lot of source code.
2 years, 4 months ago #1221257Hello Jackie,
thanks for the help and have a sunny day. -
