NooTheme Premium WordPress Theme › Forums › Timetable › Mobile view shows disabled parts of timetable
- This topic has 6 replies, 3 voices, and was last updated 5 years, 9 months ago by
therezca.
5 years, 10 months ago #1150188
Hello, I have a problem with a view of Noo timetable. Here I describe:
1. On desktop view, the showcase of a class is a bit broken, because you can see just part of the time - highlighted in a blue square - I want time to be visible before hovering:
2. I need to disable the highlight of the actual day in the desktop timetable - since we dont use the dates of classes. How can I do so?
3. Mobile view, even I disable the show of the dates, you can see it in the mobile view - yellow square. And the day is in dark grey color, which dont know where is set but I didnt set it and its not possible to read it - green arrow. Btw here the view of the class is nice - you can see time properly, it is not cut like on desktop view.
Thank you a lot!
5 years, 10 months ago #1152213Dear, i can't see your image, please kindly check again or update image to imgur.com then send for me Image URL, i will check to help you.
5 years, 10 months ago #1160283I am trying to answer one more time 🙂
Question 1 is solved, rest still unsolved. Screenshot in attachment. Thank you for help
5 years, 10 months ago #1163390Hi,
2, Please send me a screenshot.
3, You can add these lines to Custom CSS:
.noo-responsive-schedule-wrap .res-sche-navigation > h3, .noo-responsive-schedule-wrap .item-weekday {
color: #fff;
5 years, 10 months ago #1175264Hi, thank you but for no. 3 - it didnt work, only the change of color worked, but the rest is still there - I need to hide the "Class" - this headline or what it is and the dates of the week. Marked green in screenshot.
For no. 2 - screenshot attached, I need all days to have same background color, no the actual date to be highlighed.
5 years, 10 months ago #1175283Hi,
3, You can use these lines:
.noo-responsive-schedule-wrap .res-sche-navigation, .res-sche-content > h2{
display: none;
2, You go to Noo Timetable -> Schedule -> Today's Background -> set white color for it:
5 years, 9 months ago #1176022Thank you it is solved!
