NooTheme Premium WordPress Theme › Forums › JobMonster › mobile view not proper
- This topic has 24 replies, 2 voices, and was last updated 5 years, 9 months ago by
5 years, 10 months ago #1162142
I have updted images in my website and it does not get optimised in mobile view. Search bar overlaps on image where texts get overlapped and does not look good.
I wanted to put my search bar belore image, just as shown in Desktop version but in mobile view, niether image is optimised not search bar.
please help
Please help
5 years, 10 months ago #1164598Please help on this ! Fix it for mobile view
5 years, 10 months ago #1164604To fix your problem, please add custom css on your site
@media (max-width: 991px){ .noo-job-search-wrapper .job-search-bg-image.job-search-slider { transform: translate(0, 0); -webkit-transform: translate(0, 0); margin-top: 0; } }Best regards.
5 years, 10 months ago #1164607I did that. Now search bar overlaps on other contents availabel below search bar. earlier it was overlapping on wallpaper. Also wallpaper is not adjusted accordingly. It is still stretched as for Desktop version
Please check.
5 years, 10 months ago #1169271Please fix wallpapper and overlapping issues soon.
5 years, 10 months ago #1169285To fix your problem, please add more custom css on your site then go to remove space like attachment
CSS code:.noo-job-search-wrapper{ height: auto !impor }Best regards.
5 years, 10 months ago #1169290Would wallpaper be also optimised by this?
5 years, 10 months ago #1169294What is wallpaper optimised ? I don't understand your question, please add custom css and remove space on your site then check your site again. if your problem still not resolved, please kindly contact with me .
5 years, 10 months ago #1169300Yes,kit does not look proper.
I did as u said but does not look good. Screenshot attached
5 years, 10 months ago #1169302Screenshot
5 years, 10 months ago #1169305Custom css is wrong, please change to
.noo-job-search-wrapper { height: auto !important; }Best regards,
5 years, 10 months ago #1169307looks better now. Thanks
Is it nor possible to reduce Wallpaper as per mobile dimension so that mobioe viewers can see it properly?
5 years, 10 months ago #1169376Sorry, can reduce image on mobile, you can use other image have content view better on mobile and desktop.
5 years, 9 months ago #1177328How to know what image size I should have which looks good both on mobile and Desktop?
What image size could be easily visible in mobile view? Currently my image is of 900 x 330 px dimension
Please suggest
5 years, 9 months ago #1178091Dear, i have check your site i see a javascript error (like attachment) if you use cache plugin to cache javascript, please check cache plugin on your site to ignore cache jQuery, if you can't check setting, please kindly contact with plugin author to help you.
best regards.
5 years, 9 months ago #1178936This the response I got from plugin author:
"I am sorry about the issue you are experiencing with jQuery and I am happy to assist you with this.
This happens because of jquery script loads after minified files that require jQuery. It has to be included after jquery. Everything still works but you have an error as provided.
The only way to resolve this is to switch to manual minify and add the scripts manually and in proper order, meaning to add jquery script at the top of the list for minification.
It can be a little tricky so make sure to add the files one by one, save the settings, and purge the cache after each file is added to minify and check your website for any issues.
Thank you! "Can you please adjust as required! Will this solve my purpose to fit image as per mobile view?
I am using W3 Total cache plugin.
5 years, 9 months ago #1181869Dear.
I disagree with W3C Total cache author reply. Because if you disable minify javascript of W3C Total cache plugin. It's working.
5 years, 9 months ago #1182759Hi
Can you share couple of sample images that I can use in wallpaper which would adjust both for Desktop and mobile automatically. I will get different images of similar dimension and try accordingly.As of now, I have disable W3 total cache plugin but still on mobile view, no wallpaper adapt as per mobile view!
Also I have added additional wallpaper of dimension 640x320 px in Welcome page, but that also does not adjust/optimize as well as per mobile view.
please help
5 years, 9 months ago #1182761Do you think WP-Rocket can help?Shall I buy that to get my performance and solve such issues?
5 years, 9 months ago #1184246Dear, The screen ratio of desktop and mobile is different and when rotate mobile the screen ratio of mobile is different. My opinion: you need use image better view on all screen but i not is designer, so i can not help you to search image.
5 years, 9 months ago #1184790I understand that you are not UI developer but since you people have developed theme, atleast you can help me the image which fits perfectly with this theme, in both mobile and desktop view.
If I get that, I can find similar sized relevant image and use it.
5 years, 9 months ago #1185845Dear, you don't understand my reply, It not dependent image size, because it use background cover It dependent to image content, eg if you use text in image, It will be cut on responsive screen. You can use images with content less impact when responsive on screens.
5 years, 9 months ago #1185847Even when I don't use text in my image, I don't see image properly optimized for mobile.
Not only image, for candidate resume also, in mobile view, every thing stick together.
I can see many things need to be well optimized to make it convenient for mobile users as we have large variety of mobile users only. please consider giving look and feel for mobile users, who have limited processing capabilities and limited internet speed.
5 years, 9 months ago #1185849I also resume and job Advanced search bar is very slow! Can't it be more responsive. please consider.
Any plans to bring companion mobile app for this theme? I really need that for my customers.
5 years, 9 months ago #1185965Sorry, we're is web develop company and we're can't create mobile app for Jobmonster theme.
