NooTheme Premium WordPress Theme › Forums › Organici › mobile version issues
- This topic has 11 replies, 2 voices, and was last updated 4 years, 9 months ago by
4 years, 9 months ago #1213157
Hi guys,
I have an issue with mobile version of your theme.
1. Can you please check why is the right side of the theme moved and not in a position as it should be?
2. Top bar isnt showing correctly when you are scrolling web on mobile
3. call now button doesnt showing correctly. pleasee check
Thnx a lot
4 years, 9 months ago #1213172Dear, Please kindly send for me admin account and your site URL via private reply, I will check details to help you.
4 years, 9 months ago #1213173This reply has been marked as private.4 years, 9 months ago #1213174This reply has been marked as private.4 years, 9 months ago #1213178Dear,
1. To fix your problem on mobile, please add custom CSS code on your site.noo-container-fluid > .wpb_row{ margin-left: 0; margin-right: 0; }2,3 I check your site but I don't understand what is your problem with menu and hotline when scroll, Please kindly give me more details with screenshot, I will check to help you.
4 years, 9 months ago #1213180Hi,
when you scroll down or when you scroll up web on mobile version hamburger is on a half of nav bar and it should be in a middle.
Please check.
Thnx a lot
4 years, 9 months ago #1213182Hi guys,
is it possible to create instagram grid layout of the photos on mobile version?
On desktop version is ok but on mobile version pics are too big.
Can you please help?
Thnx alot
4 years, 9 months ago #1213196This reply has been marked as private.4 years, 9 months ago #1213197Hi,
1. I put the code for hamburger that you sent me for mobile version but still hamburger is not completely fixed. Please scroll down and up web on mobile device and you will see the issue.
2. I managed to fix photos in instagram feed to a grid but can you please check if the code is correct?
This is the code:
@media only screen and (max-width: 476px) {#sb_instagram.sbi_col_3 #sbi_images .sbi_item {
width: 50% !important;
height: 50% !important;
float: left;
line-height: 0;
-webkit-box-sizing: border-box;
-moz-box-sizing: border-box;
}}3. On mobile landscape version when you click hamburger under the menu there is some kind of line?
Can you please check?
Thnx a lot guys!
4 years, 9 months ago #1213200Also,
photos in instagram feed in a grid are not completely wide as the content?
Can you please check that also.
screen in attach
Thnx a lot
4 years, 9 months ago #1213248Hi,
This is the code:
float: left;
line-height: 0;
Thnx a lot guys!
4 years, 9 months ago #1213262Dear,
1.3 I check Your site with responsive on mobile but i don't any issues on your site, it display like attachment, Please kindly clear cache of browser on mobile then check again.2. To fix problem of Instagram widget on footer, Please add custom CSS code on your site
.wrap-footer .wigetized #sb_instagram { margin-left: -5px !important; margin-right: -5px !important; } -
