NooTheme Premium WordPress Theme › Forums › Timetable › Mobile Device Schedule
- This topic has 16 replies, 2 voices, and was last updated 5 years, 3 months ago by
5 years, 4 months ago #1212938
Hello Noo Theme.
The mobile version doesn't work properly. Classes are not visible and the schedule doesn't adjust to mobile screen size. Please help.
Shirley
5 years, 4 months ago #1212940Also, is there any way to have classes in 30 min slots instead of 1 hour?
5 years, 4 months ago #1212942This reply has been marked as private.5 years, 4 months ago #1212984This reply has been marked as private.5 years, 4 months ago #1212991Dear, I check your site and i see the schedule is show on mobile but with White background, so i can't see it (see attachment). Please go to edit your class category and change setting 'Color' to other color (not use white) because deafult text of class on mobile is white.
Also, the schedule not support setting time steps, it use deafult 1 hours.
5 years, 4 months ago #1213002This reply has been marked as private.5 years, 4 months ago #1213003This reply has been marked as private.5 years, 4 months ago #1213008Dear.
1. The plugin not support open Popup on Mobile driver.
2. I have fixed problem when save setting on your site, Please check your site again.
3. Sorry, the plugin not support custom font.5 years, 4 months ago #1213013This reply has been marked as private.5 years, 4 months ago #1213035This reply has been marked as private.5 years, 4 months ago #1213051Dear, Please kindly update Noo Timetable plugin on your site to latest version 2.1.4 then check your site again, the hide time range is fixed in plugin latest version.
5 years, 4 months ago #1213117Hi.
There are no updates available.
5 years, 4 months ago #1213125Dear, You can download plugin latest version from Codecanyon and delete old version on your site to re-install latest version again.
Or you can use Envato plugin to update plugin via admin panel.
5 years, 4 months ago #1213138This reply has been marked as private.5 years, 4 months ago #1213140Dear, I have check and i see a problem in Noo Timetable plugin. I have fixed it on your site. Now, please check your site again.
5 years, 3 months ago #1213225This reply has been marked as private.5 years, 3 months ago #1213238Dear, I don't understand ' The time still shows but I will just keep it like that.' Please kinldy give me more details.
