I decided not to use 'Feature List', and I changed the fonts using HTML, so I don't need help with the above issues anymore.
However, I have a new issue...
I'm using the 'Button' element in WP Bakery. After I customize it, I click 'update' and then load my website in another window to view the changes, but there's a problem with the button design: It moves to the left, changes colour and cuts off half the text.
I've attached screenshots, so you can see what I mean.
I've started again with new button elements several times, but it keeps happening. Even when I reload the WP Bakery frontend builder.
Any ideas for how to stop this from happening?
Will.
