NooTheme Premium WordPress Theme › Forums › JobMonster › Manage Jobs page options
- This topic has 8 replies, 2 voices, and was last updated 6 years, 5 months ago by
6 years, 6 months ago #1079678
AnonymousInactiveTopics: 46
Posts: 55Hi,
Please check if the below options are possible for the Manager Jobs section in Employer Dashboard? Please refer to the attached image.
1. Can we move the Note below "We found xx jobs" to the bottom of the page?
2. It is mentioned that the Featured Jobs can not be reverted. That means an employer can not un-feature the job. Why is it this way? If an employer has some new jobs and he wants to change the featured Jobs he should be able to do it by clicking on the star icon under "Featured?" column.
3. Can we enable/disable some columns in this table?
4. Can we have Job Publish Date instead of Job Closing Date in this table? This way the jobs can be sorted for the latest published jobs or oldest jobs for whatever action that needs to be taken.
5. Can we remove "Notify email" part from under the Job Title
rgds
hemant
6 years, 5 months ago #1079735Hi,
With the above requirements you will need custom in source code.
You can find to this file and custom it:
(\wp-content\themes\noo-jobmonster\layouts\dashboard\manage-job.php)
Note: you should use the Child Theme to custom for it.
6 years, 5 months ago #1079845
Posts: 55Hi,
Can you do it as a paid service?
rgds
hemant
6 years, 5 months ago #1079935
Posts: 55Hi,
Any update for my request.
rgds
hemant
6 years, 5 months ago #1080120Sorry, we currently do not provide source code customization services.
I updated the issue 1,4,5 in the Child theme folder
Please download -> install on your site and activate it.
3, The function featured job is used for job package. Whenever the user enables a Job Featured, the number of Job Featured will decrease by 1 and update to the database. So I don't think there's any reason to reverted it.
2, Currently I can not help you update this problem, it takes quite a while.
6 years, 5 months ago #1080164
Posts: 55Thank you tb. Your help is appreciated.
I tried installing the child theme. But not yet activated it. I just viewed the Live Preview. I think some other changes which I have made to my site need to be now applied to child theme. I will do that.
Would you please check if point number 4 is covered in the child theme prepared by you. Because when I saw the live preview before activating the child theme - the "Closing Date" column from the "Manage Jobs" table was removed but it was not replaced by the "Published Date". Please refer to the screen shot in my first message in this ticket.
thank you once again
rgds
hemant
6 years, 5 months ago #1080193Hi,
I have included it in the attached file.
The column "Closing Date" replace to "Publish Date".
6 years, 5 months ago #1080199
Posts: 55Thanks. I will try this and let you know.
6 years, 5 months ago #1080200Ok, I will wait the feedback from you.
