Can you please help me with a little problem I have with the main menu? I need a code or something to make it more space. I installed the translate plugin, the 2 language flags are now visible but they stay in the same row with the main menu only on the homepage, on every other page, these two flags go to the second row, which doesn't look nice.
I am using boxed version of the website. The link to the website is here:
http://www.purepassiebedandbreakfast but you can't see it now because is on a demo "maintenance" mode. I can send you logins in private message if you give me the acces to it. I'll send you the print screens. "Funny" is that I have exact the same trouble on another website, where I bought the same template few years ago: http://www.purepassieontour.com.
Can you please help? If you're sending me the code, please send me the instructions where I have to insert the code as well. Thanks in advance!
Sasa
