Hi. I cannot change the wemusic logo that appears in the initial view of the home page.
I can only change the logo that appears in the menu after the scrolling:
the manual tell me that there are 2 logo that i can manage (see the links below)
http://prntscr.com/8ee8to
http://prntscr.com/8ee94u
Please help me!
thanks in advance
alessandro
YOUR DOCUMENTATION BELOW:
Adding Logo
Wemusic allows you to add image file or use text for logo. For the image file, you can upload at any size and it will be adjusted to fit into the menu. There is an option for you to upload a retina logo to keep your logo retina ready.
Step 1: Navigate to Customizer Header Logo tab to access the logo options.
Step 2: You will see a button to turn On/Off Use Image for Logo.
If Off, you will have option to enter your site name, select logo font from Google font, font size and color for your logo.
If On, you will have two logo images to upload. The first one is for standard desktop while the second one is for retina ready devices (optional). Click the Upload button and select your logo file.
Step 3: If you are uploading a retina logo (optional), you need to upload a larger image of which dimensions are 2 times larger than dimension that your standard logo will be displayed.
Step 4: If you are using a retina logo, you must enter the logo height for standard logo.
