NooTheme Premium WordPress Theme › Forums › JobMonster › Login popup translation
- This topic has 15 replies, 2 voices, and was last updated 2 years, 10 months ago by
Ismael.
3 years, 2 months ago #1219771
Hello, I need help to fix this:
1 - Login form pop-up is translated in all pages, but not when you click it in main page.
2 - In main page, the search form is not half-half. It is shown ok in mobile, but not in laptop.
Thank you!
3 years, 2 months ago #1219772This reply has been marked as private.3 years, 2 months ago #1219774Hi.
We have checked and seen that issue on your site.
Please give us your site admin and FTP account. We will help you check it soon.
3 years, 2 months ago #1219776This reply has been marked as private.3 years, 1 month ago #1219780This reply has been marked as private.3 years, 1 month ago #1219781Hi again.
Your site return 503 service unavailable, maybe you are checking that issue. Please recheck it and let us know again when it is available.
3 years, 1 month ago #1219783Hello, excuse me, it is online now. Thanks!
3 years, 1 month ago #1219794Hi.
I have checked and helped you fix the search form issue. I also fixed the "hours ago" to translate a string in the job listing.
For the homepage, I can't find the issue with the login popup form. I also checked it in another language, it still doesn't work. I checked it on our local, it works fine with the home page.
I need more time to check it.
3 years, 1 month ago #1219803Hello,
1) SEARCH FORM - I maybe didn't explain well about half-half search fields. Please see this capture taken from desktop device:
2) LOGIN POP UP TRANSLATION - Ok, this translation is very important for the project because it is the way we explain user roles.
Thank you!
3 years, 1 month ago #1219812This reply has been marked as private.3 years, 1 month ago #1219818Hi.
I have fixed the issue with the search form. For the login popup form language issue, please give us your site FTP info. We need to debug the source code.
3 years, 1 month ago #1219824This reply has been marked as private.3 years, 1 month ago #1219846Hi.
I found the issue in the Newsletter form at the end of the page. If you remove that form, it will work fine.
Maybe it has a conflict with the Contact form 7 plugin.
You can check it.
3 years, 1 month ago #1219850Yes! Thank you so much!
2 years, 10 months ago #1220241Hello, popup login translation is ok, but when the user tries to login with an incorrect user name, it shows this red message in english:
"Error: the username XXXXX is not registered in this site. If you are unsure of your username, try your email address instead."
I cannot find where to translate it
2 years, 10 months ago #1220242Also when you copy or delete a job it displays the message "processing...". Is it possible to also translate? Thanks!
