NooTheme Premium WordPress Theme › Forums › JobMonster › Login Linkedin (redirect url problem) auth V2
- This topic has 10 replies, 3 voices, and was last updated 6 years, 4 months ago by
Sanjoob_2019.
6 years, 5 months ago #1079942
I am having the same issue as (quote #1076871) had, when login through the LinkedIn icon, pls fix the same in my theme (www.newjobzone.com).
The redirect_uri does not match the registered value
URL Generated by the theme: (https://newjobzone.com)
Theme should generate the following link: (https://newjobzone.com/linkedin-oauth2/callback)
I have already provided my login credentials previously.
Many Thanks
6 years, 5 months ago #1079943This reply has been marked as private.6 years, 5 months ago #1080116Hi,
I logined via linkedin on your site and it still normal works.
You can include the link for this issue (#1076871) to clarify
6 years, 5 months ago #1080135Hi,
it still does not work.
i open the website then select login, the page display (pic 1)
when selecting the icon LinkedIn, it does not connect (pic 2)
pls help
6 years, 5 months ago #1080151hi,
here the link. i have the same problem explain here.
https://nootheme.com/forums/reply/1076871/
6 years, 5 months ago #1080171
Posts: 155Hi,
Please check again.Login linked on your site normal works.
Redirect_uri on your app linkedin is just site main url. Ex: (https://newjobzone.com).
6 years, 5 months ago #1080306Hi,
i made a mistake.
All links above went to someone else website where the problem is solved there. (i mean the word 'newjobzone' is my website, but the hyperlink is someone else website)
my website is https://www.newjobzone.com
the website should generate (https://www.newjobzone.com/linkedin-oauth2/callback) instead of plain address above.
Again sorry for the misrepresentation in the previous messages.
Best regards
6 years, 5 months ago #1080308Has the problem been resolved?
6 years, 5 months ago #1080424Dear tinhberg,
No the problem is not resolved.
Pls help.
linkedin (compare to facebook) has so many professionals (Hr manager) that can boost my website, if they cannot log in via LinkedIn, it may be a turn off for them, and losing a potential client for me.
The problem is simple, when login via LinkedIn, instead of going to the link (https://www.newjobzone.com/linkedin-oauth2/callback) it is diverted to https://www.newjobzone.com.
and this has to be changed inside the theme itself, well this is how it was solved for the previous user.
pls help.
6 years, 5 months ago #1080460Hi,
You go to Linkedin your app and update redirect url:
Later reload your site and check again.
6 years, 4 months ago #1081057ok,
it works.
It just that i had to add / add the end of the pic shown above.
but it works, thanks a lot.
