When you search on the job page with the 'Job aAdvanced Search' widget, and you get results that only fill one page (10 results) and then filter to a bigger pool (and you need pagination) the 'Load more' button appears, but does not work and shows after a short load 'All Jobs loaded.'.
Steps to reproduce:
1. Go to: Jobs – RIX Buro
2. Filter on Branch 'Groen'
3. See that it has one page of results.
4. Add the filter on Branch 'Hout & Interieurbouw'
5. See that the 'Load More/Meer Laden' button appears at the bottom.
6. Press it.
7. It will show again after a short delay without showing new results.
8. Press it again.
9. 'All Jobs displayed' will appear without actually loading/showing the results.
