NooTheme Premium WordPress Theme › Forums › JobMonster › linkedin not working
- This topic has 24 replies, 2 voices, and was last updated 7 years, 1 month ago by
7 years, 2 months ago #1067370
hi, the register using linkedin isnt working on my site. can you help me please?
7 years, 2 months ago #1067389
Firstly, please make sure that you have added the LinkedIn API key correctly to JM Jobmonster > Settings > 3rd APIs.
Then give us your website's URL & admin account if you cannot solve your issue.
7 years, 2 months ago #1067424This reply has been marked as private.7 years, 2 months ago #1067489
We also accessed your website then checked it carefully but we didn't find the issue. In this case, please give us your FTP account privately via checking Set as private reply checkbox. We will help you to check your source code.
7 years, 2 months ago #1067527This reply has been marked as private.7 years, 2 months ago #1067537hi I spoke to my webhost, they said it is definitely a script error as the facebook and google+ buttons work fine, its only the linkedin buttons that don't work, something needs to be defined within the code
7 years, 2 months ago #1067629This reply has been marked as private.7 years, 2 months ago #1067631This reply has been marked as private.7 years, 2 months ago #1067632fsfsd message?? that's only started since you've logged in today
7 years, 2 months ago #1067635shows a string error on mobile too
7 years, 2 months ago #1067638i don't know what you've done to my site now, and you're all finished for the day by the looks of things, with my site currently broken after you've changed something
7 years, 2 months ago #1067644hi, i don't know what you've done to my website but it's caused me a whole lot of heartache!! now the search by location throws up a 404 error!
7 years, 2 months ago #1067652This reply has been marked as private.7 years, 2 months ago #1067654hi my webhost has suggested to re-install the theme? however I have over 200 jobs on there, and don't want to lose any users, jobs or settings
Can this be done? or can you fix the location search?
7 years, 2 months ago #1067664My webhost was able to resolve the location search issue so its fine now, but they cant seem to fix the linkedin issue
7 years, 2 months ago #1067668
We are really sorry for the late response because our developer needed to spend much time to check your issue.
As their check, because your website cannot load the library of LinkedIn //platform.linkedin.com/in.js
In this case, please check again your website and your hosting and make sure that you don't have any permission which blocks Linkedin library.
7 years, 2 months ago #1067723This reply has been marked as private.7 years, 2 months ago #1067809
Our theme still worked fine when your server has been upgrading PHP version 7.2
As our check, it seems that your server blocked the action "add tag script " directly so please help us to check it again.
In addition, we also got access to your account but you changed it.
Please give us again if you still need to help.
7 years, 2 months ago #1067839This reply has been marked as private.7 years, 2 months ago #1067901
Posts: 3295This reply has been marked as private.7 years, 2 months ago #1067934This reply has been marked as private.7 years, 2 months ago #1068190Hi is there any updates on this yet?
7 years, 2 months ago #1068191This reply has been marked as private.7 years, 2 months ago #1068200Hi any updates on fixing this LinkedIn issue yet?
7 years, 1 month ago #1068325
We are so sorry for the late response because we had a long holiday for the new year so we cannot help you during that time. We have just come back to work today.
For your issue: Our developers are checking the LinkedIn issue on our website carefully then release the newest version as soon as possible.
Please wait for updating our theme soon.
