NooTheme Premium WordPress Theme › Forums › JobMonster › LinkedIn login not working
- This topic has 14 replies, 2 voices, and was last updated 7 years, 5 months ago by
7 years, 5 months ago #1071958
Seems to have an issue with the new LinkedIn api or something else but it's not working
try it on financejobs.lu
you already have admin and ftp from my previous tickets if you need to look around and see what's the problem
Ivo
7 years, 5 months ago #1072029
The main issue is your LinkedIn API key so you should create it carefully and exactly. You should fill out the full information as the attached image 1 and image 2.
In addition, we also enter our LinkedIn API key to check your issue. It still worked fine. Please see the attached image 3.
7 years, 5 months ago #1072032
Posts: 3295image 3
7 years, 5 months ago #1072288Can you pls take a look. done exactly as you asked me to. the LI login opens, I enter my credentials on the LI site, then I'm taken back to my site but I am not logged in.
7 years, 5 months ago #1072289
We entered our LinkedIn API key and it still worked fine. The main issue is yours. You should create your LinkedIn API Key exactly and remember to follow as LinkedIn instruction.
If you still cannot do it, please give your LinkedIn account, we will try to help you.
7 years, 5 months ago #1072290This reply has been marked as private.7 years, 5 months ago #1072390
Posts: 3295This reply has been marked as private.7 years, 5 months ago #1072473This reply has been marked as private.7 years, 5 months ago #1072509
We tried to get access to your LinkedIn account but we didn't have the verification code 🙁
Please try to refer to this article then create your LinkedIn API key and configure your LinkedIn information correctly. http://support.heateor.com/how-to-get-linkedin-api-key/
7 years, 5 months ago #1072534This reply has been marked as private.7 years, 5 months ago #1072581
OK, we added our LinkedIn API key to your website. However, we think that you should create a LinkedIn API for your website individually.
7 years, 5 months ago #1072584
Posts: 3295This reply has been marked as private.7 years, 5 months ago #1072881This reply has been marked as private.7 years, 5 months ago #1072883This reply has been marked as private.7 years, 5 months ago #1072940
