NooTheme Premium WordPress Theme › Forums › JobMonster › Language filter not working properly
- This topic has 18 replies, 3 voices, and was last updated 7 years, 1 month ago by
7 years, 1 month ago #1067048
language filter is not working properly. If i choose for example spanish, it says that there are no listing but in fact there are as you can see in the backend
7 years, 1 month ago #1067049This reply has been marked as private.7 years, 1 month ago #1067051i just realized that it is only working when I offer multiselect for language. then its working. But if user can only choose one language then its not working!
7 years, 1 month ago #1067070This reply has been marked as private.7 years, 1 month ago #1067082
We have got access to your website then check Search by language again, it still worked fine normally.
Please see this image: https://prnt.sc/m7a7hl
We also create a CV which includes Spanish language, it still is shown when we request to search for the Spanish language.
You should check it again, then feedback us.
7 years, 1 month ago #1067107I mentioned above the problem;
„is only working when I offer multiselect for language. then its working. But if user can only choose one language then its not working!“
in your screenshot you use both language filter the one on top and the below one. But if you would only use the filter on top, which offers only one selection, then its not working with spanish!
7 years, 1 month ago #1067142This reply has been marked as private.7 years, 1 month ago #1067144This reply has been marked as private.7 years, 1 month ago #1067192
1- You said "is only working when I offer multiselect for language. then its working. But if user can only choose one language then its not working!"
But we have got access your website then create 2 Resumes (one chose 1 language and one chose 2 languages) the result is all are hidden. Please don't delete them because our developers are checking it and we will feedback you soon.
2- Because your resumes aren't contained in parent category, it only belongs child-category.
Please see this resume:https://www.seniorsatwork.ch/resumes/?s=&_job_category=105&_job_location=&_language=&post_type=noo_resume
We chose the parent category for this resume: https://prnt.sc/m7u797
In addition, our search logic is AND when you choose many fields immediately.
7 years, 1 month ago #10671941) I think the problem is that the logic is AND as you said. But I need AND/OR. how can I change or can you do that quickly?
2), But for example if I choose as a candidate child category "tree care" and the parent is "gardening work", me as a candidate would only choose tree care because I think it shows then automatically also in the parent category. With all themes I worked so far this was the logic...
you are working on my live site, how long do you need to check? because the 2 listings are not good on my live site. otherwise I can make a test site for that
7 years, 1 month ago #1067227This reply has been marked as private.7 years, 1 month ago #1067242
1- As I told above, the SEARCH LOGIC is query according to "AND" query not AND/OR as your desired.
Because this logic is suitable for a Search Form which has many options, all of our customers want to combine these options when searching. Hopefully, you can understand it.
2- Currently, the resume or job only show when you choose the category exactly, that means you should choose both of them (parent and child category if have). This logic is also WordPress logic.
In this case, you can check the logic of Post(this is the default of WordPress) to compare.
7 years, 1 month ago #1067252What about the language filter bug???
7 years, 1 month ago #1067261
Our developer is checking this issue. Please wait for us. We will try to feedback as soon as possible.
7 years, 1 month ago #1067291
Posts: 3295Please give us your information of the test website including your admin account and FTP account.
https://wordpress-235745-722297.cloudwaysapps.com/
In addition, please don't change any information so we can save time to help you.
7 years, 1 month ago #1067306Hi again.
We have checked the language filter on the resume page.
It still works fine.
Can you check it and let us know about the issue again?
7 years, 1 month ago #1067319This reply has been marked as private.7 years, 1 month ago #1067322
Please give us your admin account to access https://wordpress-235745-722297.cloudwaysapps.com/
And don't forget to give us your FTP account correctly. Our developer will access your website then check your issue again.
7 years, 1 month ago #1067324 -
