NooTheme Premium WordPress Theme › Forums › JobMonster › Job Settings
- This topic has 14 replies, 2 voices, and was last updated 2 years ago by
7 years ago #1070802
AnonymousInactiveTopics: 25
Posts: 38Hello,
Hope you are doing great. I want to change the job settings Please guide.7 years ago #1070823
Can you help us to describe your question as clearly as possible? What job section do you want to change?
7 years ago #1070826
Posts: 38This reply has been marked as private.7 years ago #1070843
Posts: 38This reply has been marked as private.7 years ago #1070870
Currently, we haven't supported this function yet but can you provide us an example about it?
We will try to check then discuss with our developer about your request. If possible, we will add it to the next version of Jobmonster theme.
7 years ago #1070896
Posts: 38This reply has been marked as private.7 years ago #1070905
We discussed with our developer about your question but currently, Jobmonster theme doesn't support this function yet. Thus, we will add it to our list features then consider adding to Jobmonster theme in the future.
7 years ago #1070914
Posts: 38This reply has been marked as private.7 years ago #1070935
This is the manage-job page so it is the default layout of jobmonster theme. We are so sorry but we cannot add fields to this page.
2 years ago #1221015This reply has been marked as private.2 years ago #1221020Hi Chaitanya HR
I'm not sure about that question. What do you want to change in the job setting? Please let us know more about that.
2 years ago #1221030Hello Team,
with reference to above picture, we would like to have auto suggestion or button of Notification Email ID, Employer Company Name and Company.
Kindly suggest the same.
2 years ago #1221053Hi.
These are the job settings for the job posting at the back end. So you will able to select the company or employer.
With the job post by admin, you need to select the company from that field to assign the job to the company.I don't know why you still need a button for the company or employer, notification email. You still have the select field for that info.
Please let us know more about that issue.
2 years ago #1221055Dear Team,
By defaulting the Company Name and Notification Email ID, we can expedite the job posting process and reduce the likelihood of errors or oversights. This approach also aligns with industry standards and best practices for job portals.
Kindly suggest me same
2 years ago #1221090Hi.
To set the default value for the "Posted by (Employer - company )" and "Company" fields on the posted job at the back-end, please edit the source code below:
wp-content/themes/noo-jobmonster/framework/admin/meta-boxes/generate-meta-box.php line 828 add the code:
$meta = ! empty( $meta ) ? $meta : $std;
$value = $meta;wp-content/themes/noo-jobmonster/framework/job/admin-job-edit.php line 90, add the 'std' attribute to the field. https://prnt.sc/G89BM4xkb1u-
