- This topic has 7 replies, 2 voices, and was last updated 7 years, 2 months ago by .
Viewing 8 posts - 1 through 8 (of 8 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › item display
Good afternoon, I need to translate the highlighted words and I can not get through the crazy translate. What is the source file where I can translate the files?
Please go to {root}\wp-content\themes\noo-palazzo\assets\plugins\DataTables\datatables.js
First, copy source code of datatable.js file to {root}\wp-content\themes\noo-palazzo\assets\plugins\DataTables\datatables.min.js
Then find these text in this file. Also see these attached images
Hi again,
We helped you to copy the source code from datatable.js file to {root}\wp-content\themes\noo-palazzo\assets\plugins\DataTables\datatables.min.js
Now you can find these text as our guide then edit them normally.
Hi again,
We have got access to your file then changed it, it still worked fine. Please see this image: https://prnt.sc/m7tngq
You should check it again, then make sure that you have refreshed your website after finishing.
Check it, then feedback us.
Good night sir,
Sensational! was changing the wrong file. Now it worked.
Thank you sirs!
