NooTheme Premium WordPress Theme › Forums › Timetable › Issues with modal popup on touch devices
Tagged: modal, schedule popup, third party themes, touch
- This topic has 4 replies, 2 voices, and was last updated 5 years, 5 months ago by
ekl.
5 years, 5 months ago #1208373
I'm having some issues with the "modal popup" from the schedule grid view on touch devices, I can provide a live access to the problem since the page is already available publicly online (just not linked/listed on the website), but I'd prefer to keep the url private
In short, on touch devices big enough to show the schedule grid view and the popup, the modal popup is initially empty: tapping any class element generates an empty popup (the "window" is there, but there is no text/image, and checking the HTML.. well, the text is actually missing, it's not hidden! something it's not set properly for weird reasons, until the user touches something in the filters. selecting any filter, and/or going back to "all categories", makes it work as expected.. works both using dropdown and list view for the filters.
i noted the issue on tablet devices (iPads, 9.7" and 12.9") but it can be replicated using a desktop browser in dev mode acting like an iPad or similar touch-enabled tablet devices, and it works both on webkit and gecko based browsers
I am pretty sure this is a conflict with something in the theme I'm using (switching to another theme, the popup works as expected) and in the meanwhile I'm in touch with the theme support too, but I'd guess it's easier for your devs to understand what's wrong here. In case it can't be fixed on this side or it's something that should be fixed on the theme, I'll report the issue in details to the theme devs too, but I really think we need your deep-knowledge on the code to understand.
5 years, 5 months ago #1208374This reply has been marked as private.5 years, 5 months ago #1208384A few more informations i found doing some tests: I tried to load the page with touch simulation enabled (on firefox dev tools) and as expected, the popup was "empty"; without reloading the page, I disabled the touch simulation on the dev tools and clicked on a class block, activating the popup, and it was correctly filled with data from the class i clicked; finally, i re-enabled the touch simulation and tried tapping on different blocks: now the popup is always filled with datas referring to the class block i clicked earlier, not the one i'm tapping on with the simulated touch. I'd guess that clicking actually sets something in the code filling the popup fields that's not set if the event is generated with a tap/touch
I hope this can help you to narrow the possible causes, let me know if i can help in any other way
5 years, 5 months ago #1208405Dear, i check your site but i don't understand what is problem on your site, please kindly give me more details your problem with screenshot or video, i will check to help you.
5 years, 5 months ago #1208448This reply has been marked as private. -
