NooTheme Premium WordPress Theme › Forums › JobMonster › Importing companies with custom fields
- This topic has 7 replies, 2 voices, and was last updated 7 years, 7 months ago by
7 years, 8 months ago #1069012
AnonymousInactiveTopics: 9
Posts: 34Hello,
I recently bought the WP all import plugin to be able to add companies and jobs.
I have few issues and would need your help:
- When I import data to Companies: the custom field "Location" doesn't get filled with the data. And the custom field "Industry" get filled with the data but just on the frontend, and when consulting on the backend the field "Industry" and "Location" are filled with option 1 of the select values. ( see attached pics)
This is doesn't appear to be an issue with the plugin since the custom field "Size" is getting filled correctly in the backend and the frontend.
- The logo's size is too small, is there a way to make a picture fit correctly is the square ?
Thank you for your answer
7 years, 8 months ago #1069015
Posts: 34This reply has been marked as private.7 years, 8 months ago #1069058Hi.
The company logo depends on your logo submit, if you want, we can help you add the custom code to get the full company logo.
With the WP All Import issue, please give us the FTP account. We will help you check it again.
7 years, 8 months ago #1069083
Posts: 34This reply has been marked as private.7 years, 7 months ago #1069113
Posts: 34This reply has been marked as private.7 years, 7 months ago #1069219Hi again.
The GoDaddy account doesn't correct. Please check it again. If yes, please provide the FTP account.
To get the full company logo size, you can go to file /wp-content/themes/noo-jobmonster/framework/admin/noo_company.php line 954,
change the code $company_logo = wp_get_attachment_image( $thumbnail_id, $size, false, $args ); to
$company_logo = wp_get_attachment_image( $thumbnail_id, 'full' );
Then add the custom CSS to remove the radius 50%:
.list.loop-item-wrap .item-featured, .style-1 .loop-item-wrap .item-featured { border-radius: 0; }
Thanks.7 years, 7 months ago #1069243
Posts: 34This reply has been marked as private.7 years, 7 months ago #1069404
Posts: 34could you please get back to me on the backend problem when data is imported ?
