NooTheme Premium WordPress Theme › Forums › JobMonster › I’m facing issues after installing the theme and its plugins.
Tagged: error, issue, woocommerce, WPBakery Page Builder
- This topic has 10 replies, 2 voices, and was last updated 2 years, 9 months ago by
2 years, 9 months ago #1220316
AnonymousInactiveTopics: 5
Posts: 16Hi,
we bought a new license for our website, but after installing the theme and its required and recommended plugins, the theme is not working correctly, for instance, the customizer page just keeps loading without showing anything, and when I activate the WPBakery page builder plugin, it shows the message as in the screenshot below.
and also, when I go to the quick setup tab and try to click on "Correct Now" button, it's not working.
We're facing a lot of issues with pages, I even can't add a new page.
please, we need your help, we can send you the login details if you want.
2 years, 9 months ago #1220324
Posts: 16This reply has been marked as private.2 years, 9 months ago #1220326Hi.
I have checked and helped you import the demo data with the WPBakery page builder.
2 years, 9 months ago #1220327
Posts: 16Hi,
Thank you, but my issues weren't in importing demo content, there's an error when I try to add new page (see below in screenshot), edit page with wpbakery still not working, and the theme is very slow, please try to check these pages and customizer, they aren't working correctly from my side.
2 years, 9 months ago #1220333
Posts: 16Hi Jackie
We are waiting 2 days now for your reply, please we need support as soon as possible.
the theme isn't working correctly, some pages aren't working correctly.
Kind regards
2 years, 9 months ago #1220340Hi.
We have checked and fixed that issue on your site.
Now you can edit your create a new page with WP Bakery page builder.
2 years, 9 months ago #1220341
Posts: 16Hi,
Unfortunately, the issue is still existing, when I try to edit using WPBakery it shows as below in screenshots. (Have you tried to edit a theme page using WPBakery? does it work good from your side!!?)
we couldn't figure out what causes these issues!
please, can you try to delete theme and install it again, maybe i did something working while installing the theme?
King regards.
2 years, 9 months ago #1220342Hi.
I'm afraid the issue is from your browser cache. It works fine on my browser.
2 years, 9 months ago #1220343
Posts: 16Hi,
yes, I noticed that it's started working but this when I deactivate Woocommerce Plugin, why? is this because not compatible with each other (the theme and WooCommerce plugin)? I connected with WooCommerce support to see if the issue is from their side? can't you help me with this issue?
Kind regards.
2 years, 9 months ago #1220347
Posts: 16Hi,
The issue is fixed thank you.
2 years, 9 months ago #1220355Thank you for your feedback.
