NooTheme Premium WordPress Theme › Forums › Mebla › I can not edit template
- This topic has 9 replies, 3 voices, and was last updated 6 years, 11 months ago by
7 years ago #1075170
install all the plugins, but I try to modify the content and it is impossible, I can not modify the bagraund of the photographer and the herader
7 years ago #1075179Hi.
To change the heading background for shop page, please go to customizer/woocommerce/shop page, you will see the option heading background image.
Please check it and let us know again if you need the help.
7 years ago #1075263it does not work to edit this ... I leave the image ... the slider does not work either, it does not work, I can not edit the wishlist button and the link does not work, but the page does work
7 years ago #1075265I need to edit the titles to translate them
7 years ago #1075297
1- Because you haven't imported the sample data of Slider Revolution plugin. In this case, please find our sample in our package then imports to Slider Revolution > Import Slider to get rid of the above issue.
2- You can use Loco Translate plugin then translate Related Products in our language file.
7 years ago #1075331Hi again.
1. With the revolution slider issue, as I see you have missed the slider demo data.
Please give us your site URL, admin account. We will help you check it soon.
Don't forget to give us the correct URL have that issue.
6 years, 12 months ago #1075684hola, he logrado manipular con plugins la template, pero lo que no esta funcionando son los filtros que ordenan los productos por precios, del precios mas bajo al mas alto, tmapoco puedo agragar el filtro de ordenar por productos destacados.
es mi primera vez con wordpress, ulo trabajar en condigo html5 y css3 y un poco de php, por eso necesito poder manipular la template... y esta template ha limitado mucho mi trabajo, he tenido que mezchar mi trabajo en html5 con tu template de wordpress
esta es la url
6 years, 12 months ago #1075685hello, I managed to manipulate the template with plugins, but what is not working are the filters that order the products by price, from the lowest prices to the highest, I can not add the order filter for featured products.
is my first time with wordpress, I work in condigo html5 and css3 and a bit of php, so I need to be able to manipulate the template ... and this template has limited my work, I had to mix my work in html5 with your template from wordpress
this is the url
6 years, 12 months ago #1075686with visual composer you can not do almost anything, just change a few elements
6 years, 11 months ago #1075768Hi again.
The WPBakery builder just uses to build the home page content.
With the shop page, the filter is the default of WordPress, it still works fine on our site.
Can you give us your site admin, FTP account? We will help you debug the filter issue on the shop page soon.
