NooTheme Premium WordPress Theme › Forums › JobMonster › how to create a feature jobs with visual composer and chnage of colour
- This topic has 7 replies, 4 voices, and was last updated 6 years, 6 months ago by
6 years, 7 months ago #1078230
I have created some jobs which were displayed in the recent job featured but how do I replicate or create set of new jobs for featured jobs as this was empty in the image attached.
Secondly, how do I changed the colour from yellow to another colour especially red as depicts by the logo of this website? See this in the image attached.
I have been trying your support for the past two weeks, am not happy that it takes such a long time to get to your support arm, not a good experience as a starter on this jobmonster theme.
I am using the video downloaded from youtube on your theme to work on this theme.
6 years, 7 months ago #1078232This is another issue entirely on DEMO not working?
We got this error notification (copied below for your attention)from our hosting company after initial installation that demo install plugin was not working which was observed too but was ignored due to the ability to work with the video downloaded which explained how to set-up this jobmonster theme. Read below the error notification........
Howdy!
Since WordPress 5.2 there is a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with one of your plugins, Installer Plugin.
First, visit your website (https://www.<wbr />heraldhrconsulting.com/) and check for any visible issues. Next, visit the page where the error was caught (https://www.<wbr />heraldhrconsulting.com/wp-<wbr />admin/themes.php?page=easint&<wbr />demo_install=true) and check for any visible issues.
Please contact your host for assistance with investigating this issue further.
If your site appears broken and you can't access your dashboard normally, WordPress now has a special "recovery mode". This lets you safely login to your dashboard and investigate further.
https://www.<wbr />heraldhrconsulting.com/wp-<wbr />login.php?action=enter_<wbr />recovery_mode&rm_token=<wbr />jrGURgs3VMM1Ob4GgxXwFS&rm_key=<wbr />aLZFfzr4BrPwTOAmElxBpf
To keep your site safe, this link will expire in 1 day. Don't worry about that, though: a new link will be emailed to you if the error occurs again after it expires.
Error Details
An error of type E_COMPILE_ERROR was caused in line 1101 of the file /home/hhrc/Heraldhrconsulting.<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />com/wp-content/plugins/easy_<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />installer/admin/importer/<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />wordpress-importer.php. Error message: Cannot redeclare wordpress_importer_init() (previously declared in /home/hhrc/Heraldhrconsulting.<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />com/wp-content/plugins/<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />wordpress-importer/wordpress-<wbr style="color: #222222; font-family: Arial, Helvetica, sans-serif; font-size: small;" />importer.php:1219)6 years, 7 months ago #1078258Hello
6 years, 6 months ago #1079140this is over 3 weeks and 5 days old that you have failed to reply to our raised issues, is this fair? can you refund our money while we delete your theme?
6 years, 6 months ago #1079323
Posts: 155Hi.
1.If you want to display featured job you need set featured for job in job dashboard.
2.you can change color button at primary color in customize/Design and Layout.
3.This error due you install plugin easy installer.
you can submit admin account and FTP account , we will help you fix.
6 years, 6 months ago #1079476For almost two months, you did not offer any support and just hang us out. We just seek a refund via Envato now because of your unexpected late reply. As a matter of fact, we are surprised to see your reply, almost when we have four months left for the support to expire.
Your reply copied below is not clear
3. This error due you install plugin easy installer.
Await your reply.
6 years, 6 months ago #1079477How do we fix the broken lines on the website?
6 years, 6 months ago #1079540Hi,
If you are using any WordPress Import plugin, please deactivated it and try again.
If it is unsuccessful, please send me admin account (Set as private reply). I will help you check.
