Hi, I am working on a site and need to create a simple monthly calendar of events, I'd like to display it like the example you show on Envato, See attached "Capture.jpg" but I also want to show a sliding month above the calendar (see attached "capture2.jpg"). Nice, clean, simple, how do I do this? Is there a shortcode for it?
Also, in my current event calendar, the actual event title, times are unreadable as they seem to be white text on a white background or seem to have "display:none;" set! I have changed the CSS to try and make the events visible but can only make the title visible so far...
Hopefully you understand what I'm after ๐
Thanks in advance!
