NooTheme Premium WordPress Theme › Forums › Palazzo › home page and advanced search do not work
- This topic has 18 replies, 4 voices, and was last updated 6 years ago by
6 years ago #1085522
we are experiencing the following problem:
on our website we have placed search on home page. When a user selects any data in the filters and presses the search button he's taken to a result page with all properties listed - unfortunately not fitlered.The same happens when the user starts filtering from other pages. The ajax filter is working, but we need the fitler to work on search button click as well.
Regards!
6 years ago #1085678Hi,
Please send me link your site and wp admin (Set as private reply)
I will help you check.
6 years ago #1085691This reply has been marked as private.6 years ago #1085693Please bear in mind, that we needed to make some extra work on the plugin, so we have neighbourhoods in the search to be displayed correctly according to the language .
6 years ago #1085779Sorry for the delayed reply.
Firstly, can you update the topic to the latest version?
You go to Palazzo -> Dashboard -> Update Purchase Code
Later, you go to Dashboard -> Update -> update version for Palazzo
If the problem persists I will help you check it.
Note: you should backup theme before updating.
6 years ago #1085835Hello,
unfortunately the problem still persists.
6 years ago #1085849Hi,
we've updated the theme. Also we've applied some changes we needed in the code of the plugin and the theme to match our needs. Please bare them in mind.
6 years ago #1085850also there are changes done by your colleagues upon our request, so please - fix the search, without crashing what both you and we have changed 🙂
6 years ago #1086031This reply has been marked as private.6 years ago #1086064This reply has been marked as private.6 years ago #1086073This reply has been marked as private.6 years ago #1086131This reply has been marked as private.6 years ago #1086174This reply has been marked as private.6 years ago #1086175This reply has been marked as private.6 years ago #1086234Hi,
If you have any other issues please create a new topic and we will support you
6 years ago #1086263Hi,
the current problem with the search is not solved.6 years ago #1086333Hi,
I have been fixed this issue.
6 years ago #1086556This reply has been marked as private.6 years ago #1086718This reply has been marked as private. -
