NooTheme Premium WordPress Theme › Forums › JobMonster › Hide post author in recent posts shortcode
- This topic has 12 replies, 2 voices, and was last updated 7 years, 5 months ago by
adage.
7 years, 5 months ago #1072677
How to Hide post author in recent posts shortcode ?
7 years, 5 months ago #1072703
Please add this Custom CSS segment to Customizer > Additional CSS to hide it:
.loop-item-content p.content-meta a{display:none;}
7 years, 5 months ago #1072741Hi,
This also hides the date, but I need the date.
7 years, 5 months ago #1072799
We also got access to your website then tried to check this Custom CSS segment, it worked fine. Also, see the attached image for more details.
7 years, 5 months ago #1072822Hello and thank you,
In deed it works fine. Except for the coma, which should also disappear, since there is no more author.
Thank you.7 years, 5 months ago #1072843
Please delete this comma in {root}wp-content/themes/noo-jobmonster/framework/functions/noo-html-shortcodes.php line 1100
7 years, 5 months ago #1072871Could you please confirm when I will update the theme this change won't be affected ?
Thank you.7 years, 5 months ago #1072917
You should write it to your child theme because it will be lost when updating our theme.
7 years, 5 months ago #1072948Hello and thank you,
I've just tried this with no success.
Could you please check it out.
Thank you.7 years, 5 months ago #1072990
Please provide us with your website's URL & admin account and FTP account privately via checking Set as private reply checkbox. We will help you to check this.
7 years, 5 months ago #1073048This reply has been marked as private.7 years, 5 months ago #1073106
We have got access to your Child Theme then found that you haven't required the changed on the functions.php file of ChildTheme. Also, see the attached image.
We also helped you to make it for this question. Similarly, you should add the required Code by yourself which you asked on other topics.
7 years, 5 months ago #1073319Thank you ; this worked.
