NooTheme Premium WordPress Theme › Forums › JobMonster › Googlemap job detail
- This topic has 11 replies, 2 voices, and was last updated 3 years, 11 months ago by
aureludo.
4 years ago #1219300
I would like to display a google map on a job page. Is there a function? if yes which one ?
4 years ago #1219307Hi.
Do you mean the job details? Yes, we have supported the google map on the job details.
4 years ago #1219311Hi,
yes, i would like seen google map here (developpement server 🙂 )
4 years ago #1219324hi
here
thanks
4 years ago #1219326Hi again.
Please use the field type Map Picker for the _full_address field. https://prnt.sc/I6KIuoZNNLtp
That will help you display the map on the job details.
3 years, 12 months ago #1219334hello
i'm active but error in the console
Uncaught ReferenceError: google is not defined
at locationpicker.jquery.js:439:20
at locationpicker.jquery.js:463:2
google-map-custom.js:5 Uncaught ReferenceError: google is not defined
at google-map-custom.js:5:20Thanks
3 years, 12 months ago #1219341Hi.
I'm afraid the issue is with your Google API key, please recheck it again.
Or give us your site URL, and admin account. We will help you check it.
3 years, 12 months ago #1219342Hi
ok i will check my api key
what should be authorized for the key?
3 years, 12 months ago #1219353Hi.
Please check the Maps JavaScript API, and don't forget to add your site URL to the API key config.
3 years, 12 months ago #1219360Hello,
Here is the configuration for me everything seems ok
https://ibb.co/t44myZq
https://ibb.co/f4cLFNdThanks
3 years, 11 months ago #1219390Hi again.
Please input the address in the address field, https://prnt.sc/p6L-AynHkPlu
That will help you display the map on the job details. I don't see any info on that field on your website.
3 years, 11 months ago #1219419Hi,
if I fill in the field nothing is displayed as shown in the screenshot with the following errors
to connect to the site the account is still active here
https://nootheme.com/forums/topic/structured-data-for-google/
thanks
