NooTheme Premium WordPress Theme › Forums › Palazzo › Google maps not working
- This topic has 10 replies, 2 voices, and was last updated 7 years, 7 months ago by
7 years, 7 months ago #1068656
Hi Google maps have suddenly stopped working on my site. Please check the screenshot below:
It says "Uncaught TypeError: Cannot read property 'PlacesService' of undefined" in the console, so I think that' s the reason.
7 years, 7 months ago #1068657This reply has been marked as private.7 years, 7 months ago #1068671
As other our answer, please check your website's URL again then feedback us.
7 years, 7 months ago #1068696This reply has been marked as private.7 years, 7 months ago #1068770
We have got access to your website then checked this issue but we didn't have access to your Dashboard. Because you've changed your information.
As our checked, you haven't added a premium Google API key yet. That causes this issue. Please see this attached image.
In this case, please refer to this documentation https://developers.google.com/maps/documentation/javascript/get-api-key then try to create a new API key for map exactly.
In addition, please give us your admin account and FTP account exactly and keep to remain it during support time.
7 years, 7 months ago #1068825This reply has been marked as private.7 years, 7 months ago #1068852
Please give us your admin account and your FTP account correctly. Because we cannot get access to your website.
You should check it carefully before giving us. Thus, it will save time for us.
7 years, 7 months ago #1068896This reply has been marked as private.7 years, 7 months ago #1068918
We also got access to your website then turn on debug to check this website.
The issue from your API key, it doesn't correct. It said, "No API keys" In this case, please check your API key again or you can create a new API key exactly. Also, see this attached image.
Please check it again, then feedback us.
7 years, 7 months ago #1068968I was using the right API key but there was a plugin conflict. which was causing the issue.. I found it and I removed it and all is working fine now. Thanks.
Please mark this issue as resolved.
Cheers!
7 years, 7 months ago #1068983
Ok, that's great when you solved your issue by yourself.
If you have other questions, don't hesitate to ask us. We are ready to help you.
