NooTheme Premium WordPress Theme › Forums › JobMonster › footers are left aligned on mobile.
- This topic has 18 replies, 3 voices, and was last updated 6 years, 6 months ago by
6 years, 8 months ago #1083317
can you fix the footers are left alligned on mobile. and can you check maps not appears on JOBS or Employer Profil.
access info in next chat.
regards
6 years, 8 months ago #1083318This reply has been marked as private.6 years, 8 months ago #1083320Hi,
I checked your site and map still normal works.
You want to edit the footer how, you can describe more clearly.
6 years, 8 months ago #1083330This reply has been marked as private.6 years, 8 months ago #1083337Hi,
I added some CSS lines to style.css of Child Theme.
6 years, 7 months ago #1083548This reply has been marked as private.6 years, 7 months ago #1083549Hi,
We will update this issue in the next few days.
6 years, 7 months ago #1083557This reply has been marked as private.6 years, 7 months ago #1083575Hi,
We have released a new version on Themeforest, you can update it now.
6 years, 7 months ago #1083611Hi the update is good for employer and candidat saved field. (Catégorie and location ) that fix. But for job alert that doesnt work, not saved and cant use job alert. Can you try and fix please.
Regards
6 years, 7 months ago #1083689
Posts: 155Hi,
I fixed it for you.
6 years, 7 months ago #1083785This reply has been marked as private.6 years, 7 months ago #1083847hi,
can you fix the first image and search bar on home page please. layout its wrong since update.
regards
6 years, 7 months ago #1083850Hi,
Please send me wp admin account.
I will help you check.
6 years, 7 months ago #1083916This reply has been marked as private.6 years, 7 months ago #1083946Hi,
I have a few updates on your site. Please reload your site and check again.
6 years, 7 months ago #1084411hi,
can you check again job alert and alert cv please. that doesnt work. many fields dont keep information.
regards
jack
6 years, 6 months ago #1084468Hi
Do you have time To fix problem with job alert soon please?
Jack
6 years, 6 months ago #1084539Hi,
The issue has been solved.
