NooTheme Premium WordPress Theme › Forums › JobMonster › Error GoogleMaps
- This topic has 18 replies, 2 voices, and was last updated 3 years, 8 months ago by
3 years, 9 months ago #1219644
Hello Jackie
Can you look why the Googlemaps map is not displaying please?
https://www.emploivelo.com/offre-emploi/vendeur-cycle-toulouse/
the API key is good as well as the Google Maps configuration
I'll post the credentials in another message.
Please note the site is in production,
thank you
3 years, 9 months ago #1219645This reply has been marked as private.3 years, 9 months ago #1219680hi.
Can you turn off the Security check? https://prnt.sc/F25_eYV7uomE
I can't access to your back-end.
3 years, 9 months ago #1219695hello
it's ok now ?
thanks
3 years, 9 months ago #1219706Hi.
It has an error when I tried to edit the source code in this file: wp-content/themes/noo-jobmonster/framework/functions/noo-enqueue-js.php
Please give me the FTP account, I need access to your source code to help you solve the issue.
3 years, 9 months ago #1219708This reply has been marked as private.3 years, 9 months ago #1219709hi
I just uploaded the noo-enqueue-js.php file on the server but still the problem
3 years, 9 months ago #1219711Hi.
I have fixed the map display issue on your site.
3 years, 9 months ago #1219712Hello,
it's perfect thank you, great!
Which file have you modified please note it on my side if it starts again with an update
Thank you in advance and good day
3 years, 9 months ago #1219714ok i'm see in the server
file :
- job.js
- google-map.js- google-map-custom.js
- noo-utilities.php
noo-enqueue-js.php
it 's allright ?
3 years, 9 months ago #1219716Yes, that is right. You can back-up that file on your server.
3 years, 9 months ago #1219738Hello,
it doesn't work anymore π
https://www.emploivelo.com/offre-emploi/mecanicien-cycles-atelier-itinerance-paris/
I did not modify anything on my side in the code however, can you look again
3 years, 8 months ago #1219747This reply has been marked as private.3 years, 8 months ago #1219749This reply has been marked as private.3 years, 8 months ago #1219750on the site in production (the one you have access to) I don't have the same error now
jquery.min.js?ver=3.6.1:2 Uncaught ReferenceError: google is not defined
at initialize (google-map-custom.js:5:24)
at HTMLDocument. (google-map-custom.js:36:41)
at e (jquery.min.js?ver=3.6.1:2:30038)
at t (jquery.min.js?ver=3.6.1:2:30340)3 years, 8 months ago #1219768Hello Jackie,
Happy New Year and good health !
An idea of ββthe problem ?
3 years, 8 months ago #1219819Hi.
I have checked your site and found the issue from the Advanced custom field pro. Maybe you have added the Google Map API key on the config of that plugin. After deactivating that plugin, the map works fine.
3 years, 8 months ago #1219820Hello,
Ok thanks but you spit the site by disabling modules and deleting a variable in ACF Pro π
I have just reactivated everything and redo the ACF variable I will find out why it does not work because before it worked very well
3 years, 8 months ago #1219821Hi.
The issue from the API key call from the ACF plugin:
<script data-service="acf-custom-maps" data-category="marketing" type="text/plain" data-cmplz-src='https://maps.googleapis.com/maps/api/js?libraries=places&key=AIzaSyD0NUh50KJL3yOTt3NnTZFm2MiKZCz9w3k' id='google-map-js'></script>
Maybe you should disable that field or remove the API key in the ACF config.
