NooTheme Premium WordPress Theme › Forums › JobMonster › Employer approval application button is not working
- This topic has 27 replies, 4 voices, and was last updated 9 months, 1 week ago by
TCG.
5 years, 6 months ago #1207952
Hi, i noticed this error after i logged in as employer.
Employer cannot approve or reject any application. After click approve button, will show out a pop up to send message to candidate. But, after that the status is still pending and show "no application approve" notification.
Please help to check what is this error. Attached i screenshot the page after i click the approve button.
5 years, 6 months ago #1207976Dear. I think that problem maybe you not set Company for Job 'Branch Manager' Please go to edit job and check 'Company' setting (see attachment) and sure it's selected your company.
5 years, 5 months ago #1208273dear dangdv, I have the same problem. Does your answer above mean I have to edit job for each company every time to correct the company name? Isn't that a problem?
5 years, 5 months ago #1208313Dear @freeadda default if Employer add job on front-end, it will work, but if you add Job via admin, you need select 'Job Company' data. Please check your site again.
5 years, 5 months ago #12083225 years, 4 months ago #1209245Hi,
Currently i try again to post a job from front end, but it seems not capture the company field. The employer company is not capture.
How to solve this?
5 years, 4 months ago #1209261Dear, Please kindly send for me admin account and your site URL via private reply, i will check details to help you.
5 years, 4 months ago #1209265This reply has been marked as private.5 years, 4 months ago #1209279Hi @dangdv,
Can i have the solution for this?
5 years, 4 months ago #1209284This reply has been marked as private.5 years, 4 months ago #1209285I think as administrator role is no problem. But if set as employer role will got problem.
5 years, 4 months ago #1209286This reply has been marked as private.5 years, 4 months ago #1209287Dear, I check again i see a problem when post job, please kindly update Jobmonster theme on your site to latest version 4.6.6.3 and check again.
5 years, 4 months ago #1209288I cannot update the theme because i already done so many customisation on the theme folder.
Can u sent me which file or line i should edit?
Please help. I really out of time on this project. My client is chasing me to live the site. Only left this problem
5 years, 4 months ago #1209289This reply has been marked as private.5 years, 4 months ago #1209290This reply has been marked as private.5 years, 4 months ago #1209293This reply has been marked as private.5 years, 4 months ago #1209295This reply has been marked as private.5 years, 4 months ago #1209296This reply has been marked as private.5 years, 4 months ago #1209310This reply has been marked as private.5 years, 4 months ago #1209314With plain ftp insecure option still not login to FTP of your hosting. Now, you can fix it with your self, Please:
1. Go to file 'noo-jobmonster/framework/admin/noo_form_handler.php' and search code (see attachment change-code.png ):
$company_id = jm_get_employer_company( get_current_user_id() );
Change to :
//Save company before if (empty($company_id) && isset($_POST['company_name']) && Noo_Member::is_employer() && ($saved_company_id = self::save_company($_POST)) ) { $company_id = $saved_company_id; }2. Go to file 'noo-jobmonster/framework/admin/noo_form_handler.php' to search and remove code (see attachment remove-code.png)
if (isset($_POST['company_name']) && !jm_get_employer_company() && Noo_Member::is_employer()) { self::save_company($_POST); }Best regards.
5 years, 4 months ago #1209317This reply has been marked as private.5 years, 4 months ago #1209319This reply has been marked as private.5 years, 4 months ago #1209323This reply has been marked as private.5 years, 4 months ago #1209324Yes, I have fixed problem on your site. Now, please check your site again.
