NooTheme Premium WordPress Theme › Forums › JobMonster › display options that are not activated in packages
- This topic has 8 replies, 2 voices, and was last updated 1 year, 4 months ago by
thierry.
1 year, 6 months ago #1222299
hi
how to put the info on the First package that we can not see the resumes (with a red cross) as is done for the “offer in front”?
the option works fine but I would like it to be displayed in the description
how do I do it?Attachments:
You must be logged in to view attached files.1 year, 6 months ago #1222324Hi.
I have edited the source code to help you display that info on the job package.
1 year, 5 months ago #1222357Hi
Merci c'est tres bien
but impossible to find the translation in locotranslate
for it's already translated in the plugin
how to translate it
Thanks1 year, 5 months ago #1222368Hi.
I have added that string to the language file. Now you can translate with the Loco plugin.
1 year, 5 months ago #1222426hi
Thanks, but I can't find this empty field
it's already filled in (see screenshot)
I've looked in the other files and it's the same
can you tell me which file or theme in locotranslate I should use
I'd like to put "No CV display"
thanksAttachments:
You must be logged in to view attached files.1 year, 4 months ago #1222452Hi.
I have checked and helped you translate the "View Resume Details" string on the package.
1 year, 4 months ago #1222463Hi
very sorry but I can see the modification on the site olivier2
but I made a copy with the new version and it doesn't work
I don't understand
I go to locotranslate, I modify the translation but I don't see any change (see screenshot)you can go to olivier3.idwebsolution.fr with your codes
and tell me what's not working
I can translate everything but this!! weirdAttachments:
You must be logged in to view attached files.1 year, 4 months ago #1222479Hi.
I have access to your oliver3 site to help you check that issue. I have edited the file in the author folder: https://prnt.sc/vMbaB18u5WpU
First, you need to click the sync button, then you will see the string "View Resume Details" to translate.
1 year, 4 months ago #1222494hi
it's ok, it works
I hadn't synchronized before making the change
Thanks -
