NooTheme Premium WordPress Theme › Forums › JobMonster › display issue of the home page on mobile
- This topic has 15 replies, 3 voices, and was last updated 6 years ago by
Recrut.
6 years, 1 month ago #1084158
I have display issue of the home page website on mobile. The content of the slider spreads out so that it is displayed over the content below.
How to fix this ?
Regards,
Recrut
6 years, 1 month ago #1084162In fact, it's the search bar of the slider which lies down below on mobile.
6 years, 1 month ago #1084163I will be able to send you screenshot in private after you will answer.
6 years, 1 month ago #1084193Hi Recrut
Thank you for feedback us
You can send image problem via : https://prnt.sc/
I will check it for you
6 years, 1 month ago #1084198Hi Haind,
Thank you for your answer.
Here's how my homepage looks like : https://prnt.sc/r0l02i
Can you fix this please ?
Regards,
Recrut
6 years, 1 month ago #1084217Hi
You can sen information login wp admin (set as private reply)
6 years, 1 month ago #1084224This reply has been marked as private.6 years, 1 month ago #1084249Hi,
You can change the height value for each device respectively to fix this problem.
6 years, 1 month ago #1084306Hi tinhbeng,
I can change the height value of the slider for the mobile.
There is an option to change the content bottom position for each device. But when I modify the value for mobile, the content position does not change.
How to fix this ?
Regards,
Recrut
6 years, 1 month ago #10843096 years, 1 month ago #1084316This reply has been marked as private.6 years, 1 month ago #1084383Hi,
Can you tell me how to make the content bottom position effective ?
Regards,
Recrut
6 years, 1 month ago #1084435Hi,
We will have 1 release this month. which has this problem.
You can wait to update it.
6 years, 1 month ago #1084443Hi,
When will the update be release ?
Regards,
Recrut
6 years ago #1084538Hi,
The update will be released later this month.
6 years ago #1084668Hi,
Regards,
Recrut
