NooTheme Premium WordPress Theme › Forums › JobMonster › Development inquiry
- This topic has 6 replies, 2 voices, and was last updated 7 years, 7 months ago by
7 years, 7 months ago #1069252
I would like to do some development on our site, and I hope you can <u>A) </u>Find out if you can do it, <u>B)</u> Find out how much it will cost? and <u>C)</u> Find out when can you do it?
<u>FIX 1: NOO LOCATION WIDGET</u>
I want to do 3 fixes on this widget:
<!-- [if !supportLists]-->A) <!--[endif]-->The parent categories must be shown as default
<!-- [if !supportLists]-->B) <!--[endif]-->When you click a parent category the list must open and show all child categories for that certain parent.
<!-- [if !supportLists]-->C) <!--[endif]-->The job count in parent categories must show number of jobs in both parent and child category.
To see what I mean please look at this URL https://www.finn.no/job/fulltime/search.html under the heading “Område”. If you click e.g. the category “Akershus” the list opens and show all the cities in Akershus. On this site you can also see how the job count should be shown.
<u>FIX 2: NOO JOB CATEGORY WIDGET</u>
I want to do 2 fixes in this widget:
<!-- [if !supportLists]-->A) <!--[endif]-->I want to show the top 15 categories as default. Top 15 should be the categories with most jobs in it.
<!-- [if !supportLists]-->B) <!--[endif]-->I want a link beneath the categories where I can choose to show all categories.
<u>FIX 3: RESUME FIELDS</u>
I want to make a function for more advanced search in resumes – I call it job match.
I want to remove the skills section that is default in resumes and replace with a set of skill-tags that also should be a search field in resume search (just like job_tag). I want the field to be a multiple skills tag with input. This way all candidates can choose skills and simply add the ones they feel is missing.
I also want to add an exact identical section for personal characteristics in the resumes.
With these new fields complemented with some new custom text fields with information I can offer a pretty advanced job match to my customers. The custom text fields I can add.
<u>FIX 4: RESUME LOCATION WIDGET</u>
I want a resume location widget that works the same way as the job location widget I’ve described in FIX 1, but off course for resumes.
<u>FIX 5: RESUME CATEGORY WIDGET</u>
I want a resume category widget that works the same way as the job category widget I’ve described in FIX 2, but off course for resumes.
Hope to hear from you soon:)
Have a nice day!
Best regards
Ray
7 years, 7 months ago #1069295Hi
I would like to do some development on our site, and I hope you can A) Find out if you can do it, B) Find out how much it will cost? and C) Find out when can you do it?FIX 1: NOO LOCATION WIDGET
A) The parent categories must be shown as default
B) When you click a parent category the list must open and show all child categories for that certain parent.
C) The job count in parent categories must show number of jobs in both parent and child category.To see what I mean please look at this URL https://www.finn.no/job/fulltime/search.html under the heading “Område”. If you click e.g. the category “Akershus” the list opens and show all the cities in Akershus. On this site you can also see how the job count should be shown.
A) I want to show the top 15 categories as default. Top 15 should be the categories with most jobs in it.
B) I want a link beneath the categories where I can choose to show all categories.FIX 3: RESUME FIELDS
I want to make a function for more advanced search in resumes – I call it job match.I want to remove the skills section that is default in resumes and replace with a set of skill-tags that also should be a search field in resume search (just like job_tag). I want the field to be a multiple skills tag with input. This way all candidates can choose skills and simply add the ones they feel is missing.
I want a resume location widget that works the same way as the job location widget I’ve described in FIX 1, but off course for resumes.FIX 5: RESUME CATEGORY WIDGET
I want a resume category widget that works the same way as the job category widget I’ve described in FIX 2, but off course for resumes.7 years, 7 months ago #1069367
Our developer has taken a look your requirement carefully but they only help you to make point 3. With other points, you should find a freelancer developer to help.
7 years, 7 months ago #1069382Hello again
Thank you. I would love to know how much your developer want for this job?
I'll check with a freelancer about the rest.
Best regards
7 years, 7 months ago #1069428
These customization requirements are opposite with Jobmonster's logic now. That's the reason why we cannot help you to do them. In case, you should find freelancer team and they will take a look your customization then give you a suitable cost.
7 years, 7 months ago #1069455Hi
Ok, you wrote that you could make point 3 - but that's ok. If you don't want the job I can ask a freelancer.
Best regards
7 years, 7 months ago #1069482
We are really so sorry when we cannot help you to customize your website. If you have other questions, don't hesitate to ask us. We are ready to help you.
