NooTheme Premium WordPress Theme › Forums › JobMonster › Delete options for members
- This topic has 11 replies, 2 voices, and was last updated 7 years, 7 months ago by
7 years, 8 months ago #1066698
hello,
I want only employers to create an account on my website. When they log in, they have the options to view or view CVs at the header top right. How can I remove those options? Thanks in advance!
7 years, 8 months ago #1066735
Please go to JM Jobmonster > Settings > Member > Who can Register: Only Employer to make your desired.
7 years, 8 months ago #1066767Hi, I already did that, but it didn't make any difference.
For the other topic "copy job" I gave you my inlog. Maybe you can also solve this problem? Hope to hear from you!
7 years, 8 months ago #1066779
Please update our theme to newest version then feedback us again this issue.
7 years, 8 months ago #1066786Hello, my update is "forbidden". I got the envato toolkit installed (including API key and all) but still it doesn't work. Hope you can help me today!
7 years, 8 months ago #1066792This also didn't work:
If you use Jetpack plugin. Please deactivate that plugin and update theme. After that, you can active again.
If not, Please go to Jobmonster/Quick Setup and click SAVE CHANGES button and try to update theme again
7 years, 8 months ago #1066794okay, I got the update. But still no difference. Please help me out. I got: Who can register: Only Employers.
7 years, 8 months ago #1066832
We have got access to your website then try to register a new user on your site. The new user only became an employer account successfully.
Also, see the attached image for your details.
Please check it again, then feedback us.
7 years, 8 months ago #1066856I want to delete the options like View resume, applications etc, because Candidates do not have this option on my site. How can I do that?
7 years, 8 months ago #1066906
Please tell us which options and button do you want to remove? And don't forget to give us images which describe it. We will help you to add a Custom CSS segment to hide it on your website.
7 years, 7 months ago #1067100Hello, see attachment, hope you can remove them for me. Thanks!
7 years, 7 months ago #1067115
You can go to JM Jobmonster > Member Menu >Employer Sub menu: Remove these fields if you don't want to show.
