NooTheme Premium WordPress Theme › Forums › JobMonster › Customization of Jobmonster
- This topic has 12 replies, 2 voices, and was last updated 6 years, 10 months ago by
6 years, 10 months ago #1081683
Dear All,
I am a beginner who started with mylisting and elementor pro and bought jobmonster because it was also featuring elementor.
I need very much the frontend help to customize the website and have faced some challenges on the Jobmonster theme regarding elementor.
I have listed my questions below and hope that you will be able to help me.
Thanking you in advance.
FS
6 years, 10 months ago #1081708Hi,
It seems your file exceeds the allowed size, please check again.
6 years, 10 months ago #1081745This reply has been marked as private.6 years, 10 months ago #1081762Hi,
1, The jobmonster Addon support "Elementor" (include Free and Pro).
2, You can't customize Job Archive page with Elementor. This is the default page to host the job, which is similar to the post archive page. You can only use Elementor to create a custom page using Jobmonster Addon
3, I imported the Slider for "Job Category home" page.
4, The section job search of "Job Listing Home" page: You can customize this option:
5, Resume Grid not work: I checking this issue
6, Review criteria: Since you use French, you can use the Loco Translate plugin and translate for theme.
7, Change black cover picture at the top: you can add these lines to Custom CSS or style.css of Child Theme:
.noo-page-heading{
background: transparent!important;
8, Add Logo: You go to Customizer -> Header -> Logo -> http://prntscr.com/q2lbdj
9, You use Loco Translate plugin and translate for Theme.
6 years, 10 months ago #1081770Hi,
I checked problem number 5.
I found these errors from the console screen. You can contact your hosting for assistance with this issue.
I create this page: https://www.recrutinc.com/resume-grid/
It will normal work when you logout (This problem I think is related to the above error).
6 years, 10 months ago #1081796This reply has been marked as private.6 years, 10 months ago #1081807Hi,
1, Jobmonster has no additional addons for Elementor Pro.
2, You can use Elementor on all pages. For content to display you need to add elementor widget.
5, Have you contacted the hosting about the issue I mentioned above?
6, Jobmonster only supports 4 fields as it is now
7, I updated CSS to custom CSS.
8, You can add these lines to custom CSS:
.colophon.wigetized{
background-color: red; // replace "red" -> your color
6 years, 10 months ago #1081824This reply has been marked as private.6 years, 10 months ago #1081845Hi,
2. Please send me a screenshot to clarify
5. You can refer this post: https://www.digitalocean.com/community/questions/blocked-by-cors-policy-the-access-control-allow-origin-mean-stack
6. You can use Child Theme and customize 2 files.
- list-comment.php (/wp-content/themes/noo-jobmonster/layouts/company/)
- noo-utilities.php(/wp-content/themes/noo-jobmonster/framework/functions/)
8. I added CSS on your site, please reload your site and check again. (remove browser cache and check)
6 years, 10 months ago #1081873Thanks a lot.
What my purpose was is, as advertised on your sales page, to use existing demo to customize for my own website.
What I see is that not all pages are editable with elementor, and most of the demo pages are empty, I have uploaded the demo twice. see attached.
5- I refered the link, They ask for the specs on the theme
6-This is starting to be complicated. I am not sure I can understand everything.
If you could help use your demo to finalize the website, it would be great. The translation did not work.
Thank you for your help.
6 years, 10 months ago #1081877Hi,
I am not sure what steps you have taken, the blank pages are not included in the demo data. You need to add "elementor addons" for them to work. (You should only install demo data once on the site.)
5. What are the specific parameters?
6. Translate: if you use multi language, you can use WPML plugin, else you can use Loco Translate plugin.
6 years, 10 months ago #1081899This reply has been marked as private.6 years, 10 months ago #1081914Hi,
- After you finish translating, please go to Settings -> General -> Site Language -> set your language.
- I mean you need to add Elementor widgets to your page, not upload the Elementor Addon plugin.
eg: this page: http://prntscr.com/q4ttk7
You need to add elementor widget on this page:
- If you want to copy the content of an existing page, you can do the following:
http://prntscr.com/q4tvve . Later create a new page with Elementor and paste.
