NooTheme Premium WordPress Theme › Forums › JobMonster › Custom fields are not saving data
- This topic has 7 replies, 2 voices, and was last updated 6 years, 2 months ago by
lucasns.
6 years, 2 months ago #1082527
Some custom fields, after entering the information and saved, are not logging the data, we are losing data.
Is attached
6 years, 2 months ago #1082530This reply has been marked as private.6 years, 2 months ago #1082542Hi,
I have updated some code lines.
6 years, 2 months ago #1082579Hi,
Thanks for the feedback
I tried changing the curriculum data of the test user. Unfortunately it is not yet saving.Could you please check?
appreciate
Att,
6 years, 2 months ago #1082588Hi,
I'm not sure what you have customized, but it seems you have used an add_filter ----> 'jm_resume_render_form_field_params' somewhere and ants for the value of $value variable are overwritten.
I tried "var_dump" $value before and after apply_filter was run.
Result:
Please check again.
Note:
- You should update the last new version for Jobmonster theme (Make sure no code is directly added to the parent theme), then check the codes you have customized from Child Theme.
- You should only enable the plugin cache when you are done editing your website.
6 years, 2 months ago #1082863Hi,
Thanks for the feedback.
All the customizations I made to the code are in the child folder. I didn't change anything in the original job-monster folder and neither change this part of filters.
What I usually do is to copy the project code to the child folder with some changes. If you want to test, you can remove the changes I made to the child folder.
I did it earlier, but it still didn't work.In the curriculum, the changes I made to child were just changing the sequence in which the fields are loaded and I also put a field manual validation. I already removed these changes to test, but they had no effect on the current issue.
I just upgraded to latest version of JobMonster via FTP.
The fields are saving the information as you showed, but at the time of rendering the fields, the saved information is not being displayed.Please, could you check?
Att,
6 years, 2 months ago #1082876Hi,
I updated a few lines of code. Please reload your site and check again.
I will update this problem in the next version.
6 years, 2 months ago #1082892Hi,
Now it's working, thank you very much!
Att,
