NooTheme Premium WordPress Theme › Forums › JobMonster › Custom application link in popup window
- This topic has 14 replies, 4 voices, and was last updated 6 years ago by
MIdsgn.
6 years ago #1084704
Hi there,
In setting job application.... I chose:
- Enable custom application link
- Yes, on both dashboard and frontendAnd it works great!
But... is it possible (maybe by CSS, to open this link in a smaller popup).
For example: width=600, height=600Hope you can help me on this one.
Thanks6 years ago #10847536 years ago #1084758The size is not that important... but I want to use a custom application link (not to the application form), and the link has to go to a popup window, not to a blank window..
(size about 600x600 but can be different)
6 years ago #1084804Hi
I will instruction you edit code in the file:
...\wp-content\themes\noo-jobmonster\layouts\job\single\detail.php at lien 67, 68:
Hope it will help you
6 years ago #1084966I am gonna try... Thanx for your help!
6 years ago #1084984Hi,
You should use the Child Theme to customize this file.
If you edit directly on the original theme, it will be lost when you update to the new version.
6 years ago #1085187This reply has been marked as private.6 years ago #1085191This reply has been marked as private.6 years ago #1085221Hi
I checked and found that you have fixed the code correctly, now you enter the url in the back-end job and check in the front-end.
Please check agian
6 years ago #1085256This reply has been marked as private.6 years ago #1085348Hi
I custom it for you, please check again
6 years ago #1085372it works thanks... but a few things changed (can I asked what did you do).
Some translations I made dissappeared, and some settings are different now.6 years ago #1085373This reply has been marked as private.6 years ago #1085392Hi,
I added css to hide the parts you want to hide in dashboard -> customizer -> custom code -> custom css
6 years ago #1085414Great! Thank you for your time. Happy with the result and your support!
