NooTheme Premium WordPress Theme › Forums › CitiLights › Contactform 7 not working
- This topic has 10 replies, 2 voices, and was last updated 5 years, 5 months ago by
5 years, 5 months ago #1208990
AnonymousInactiveTopics: 6
Posts: 20Hi,
I've set the a custom form for object using contact form 7. It is shown, but it won't send. When I click on the submit button, it doesn't do anything. Any ideas? I'll send logininformation in a new message.
5 years, 5 months ago #1208991
Posts: 20This reply has been marked as private.5 years, 5 months ago #1209012Mean, the Contact form 7 not send email on your site ? please check and sure email sender is work on your site, you can use Check Email plugin to check it.
5 years, 5 months ago #1209057
Posts: 20Hi,
No, that is not what i meant. It doesn't even give me the thank you message of contactform 7. If you want to test you can use the listing 'temp test'
5 years, 5 months ago #1209064This reply has been marked as private.5 years, 5 months ago #1209100
Posts: 20Hi,
I set wp_debug to true, but I'm not getting errors. I've also disabled most plugins to check. 1 thing I've noticed:
The newsletterform at the bottom of the homepage is also an contactform 7 form and that one is working.
5 years, 5 months ago #1209101
Posts: 20Hi,
It seems an extension to contactform 7 causes the conflict. Thanks for the replies.
5 years, 5 months ago #1209102
Posts: 20This reply has been marked as private.5 years, 5 months ago #1209117Dear, The Contact Form 7 only support send email to email address config in form, i don't understand your questions, please kindly give me more details, i will check to help you.
5 years, 5 months ago #1209126
Posts: 20Hi,
Really?
What I would like is a form that I can edit but is also send to the objectowner. But more importantly: contact form 7 has an extension to create a back-end database where the entries are stored and that is really important. As an administrator: I want to be able to view the entries of the form in the backend.
5 years, 5 months ago #1209128Dear, the Contact Form 7 not is core function of theme, please kindly check https://contactform7.com/ to use plugin.
