NooTheme Premium WordPress Theme › Forums › Timetable › Conflict with my theme
- This topic has 10 replies, 3 voices, and was last updated 6 years, 11 months ago by
6 years, 12 months ago #1070024
I bought your timetable plugin.
I created a calendar page and used the calendar shortcode. See screenshot noo-schedule-shortcode.png
When I go to preview than beneath the calendar are comments from my theme although I unmarked them in the page editor. See screenshot comments-conflict.png
When I delete the whole shortcode, put only some text in the editor, update the page then there are no comments anymore.
So there must be a conflict with your plugin which provokes the comments to appear.
What shell I do.
BTW I am developing locally...
Oliver
6 years, 12 months ago #1070143Hi,
I don't think this issue comes from plugin Noo Timetable.
You can activate the default theme and check again.
6 years, 12 months ago #1070146If possible, please create a public site. I will help you check.
6 years, 12 months ago #1070169This reply has been marked as private.6 years, 12 months ago #1070196Hi,
I checked your site. As you mentioned above, it seems that the problem comes from the Timetable plugin.
Currently, this problem fixed. Please reload your site and check again.
6 years, 12 months ago #1070252Hi tb,
thank you so much for the support. Great it's working.
Only as I mentioned above
I am devoloping with another theme locally. So, if you have a solution please share it with me. So that I can transfer it to my site.
So what did you do. Can you please tell me what to do.
6 years, 12 months ago #1070262Hi,
You go to ntt-schedule.php file (/plugins/noo-timetable/templates/shortcodes/) and add this line:
wp_reset_postdata();
6 years, 12 months ago #1070263Hi, great - it's working.
Will this be overridden again with the next update?
thx
6 years, 12 months ago #1070288This problem will be fixed in the next version.
You don't need to worry.
6 years, 12 months ago #1070290Awesome. Thanks
6 years, 11 months ago #1070351
Posts: 3295ok, you're welcome.
