NooTheme Premium WordPress Theme › Forums › JobMonster › Company Name issue
- This topic has 14 replies, 3 voices, and was last updated 6 years, 9 months ago by
6 years, 10 months ago #1074805
Hi Team,
Whenever i register as employer and confirm my email, it shows email id in the company name. And the contact number and email are empty.
Site: Jeweljobs.in
6 years, 10 months ago #1074808Also when a employer post a job and select the address are same as company, the address is never shown in the more information.
Please find attach.
6 years, 10 months ago #1074938
1- Please make sure that you have used the newest version of Jobmonster theme.
2- You should provide us with your information exactly because this is the personal issue and we need to get access to your site directly and check it.
6 years, 10 months ago #1075017This reply has been marked as private.6 years, 10 months ago #1075111
We found that you haven't updated the newest version of Jobmonster theme. In version number 4.5.2.6, we also supported the Display name field so you can enter your company name in here. After that, you will have the company name as the attached image.
6 years, 10 months ago #1075124ok, how about the second issue
6 years, 10 months ago #1075199Hi again.
With the same company location, we have checked your site again, it still works fine.
6 years, 10 months ago #1075200Please check the more information part. The pincode shows 0 and no address or city anything.
6 years, 10 months ago #1075406Any update?
6 years, 10 months ago #1075566Hi again.
With the pincode, it still appears when you input the value on the job submission form.
So you can set required for that field.
Please check the custom field config.
6 years, 10 months ago #1075579But when i select the address as company, why i need to put that information again?
That doesn't make sense.
Thanks & Regards,
Vishal S
6 years, 9 months ago #1075789Anything on this?
6 years, 9 months ago #1075992Hi again.
The pin code is the custom field. It doesn't relate with another field, that is the reason you need to input that info again.
6 years, 9 months ago #1076041Now after the upgrade, its not showing the city field in the company profile page. Only the label is shown. even in the company custom field its enabled.
6 years, 9 months ago #1076080
We are so sorry for the late response because we had some problems so we cannot help you soon.
We also checked this issue on our website then found out that this was our issue also.
Please download this file: https://app.box.com/s/999tz2jtg6z3f7nokon0dc699ef5rs6u
then replace it to {root}wp-content/themes/noo-jobmonster/framework/functions/noo-enqueue-js.php
